Old 10-17-2019, 09:05 AM
CSXengr's Avatar
CSXengr CSXengr is offline
Default Brakes on 124
I purchased a 124 with a creeper several years ago and it never has had very good brakes. So I started the work of checking them out. What I found first thing is the "Brake adjusting screw" has been broken off. I am going to attempt to drill it out and remove with an easy out. My question how long is this bolt and what size is it? Just in case I can't get a good thread size and I really need the length. FYI I have the service manuel in hand.
Thank for your help in advance.
CSXengr
_______________________________
124 w hydro lift, 124 creeper gear, 125,126,128, 129,147 electric lift, 149 w/tiller, 1200, 1450 dual 1650 w/tiller control hydro, #2 Cart, Haban sickle mower, Gannon, 17 cubic inch cart.
Old 10-17-2019, 09:26 AM
Per the Parts Manual "Screw, 3/8-16 X 1-3/4 Sq Hd Ov Pt Set" - available at your local Hardware Store.
Old 10-17-2019, 06:02 PM
CSXengr's Avatar
Thanks Roland. It came out very easily and found the bolt. Went right in and adjusted the brakes per manuel. Now the brakes work great! I wish everything was that easy. I had in done in less than an hour.
CSXengr
