-   -   Brakes on 124 (https://www.onlycubcadets.net/forum/showthread.php?t=56050)
CSXengr 10-17-2019 09:05 AM
Brakes on 124
I purchased a 124 with a creeper several years ago and it never has had very good brakes. So I started the work of checking them out. What I found first thing is the "Brake adjusting screw" has been broken off. I am going to attempt to drill it out and remove with an easy out. My question how long is this bolt and what size is it? Just in case I can't get a good thread size and I really need the length. FYI I have the service manuel in hand.
Thank for your help in advance.
R Bedell 10-17-2019 09:26 AM
Per the Parts Manual "Screw, 3/8-16 X 1-3/4 Sq Hd Ov Pt Set" - available at your local Hardware Store.
CSXengr 10-17-2019 06:02 PM
Thanks Roland. It came out very easily and found the bolt. Went right in and adjusted the brakes per manuel. Now the brakes work great! I wish everything was that easy. I had in done in less than an hour.
