Old 04-14-2019, 08:38 PM
anitasanger anitasanger is offline
Default 44c Deck on my 100?
Hey guys, I picked up a crusty 44c deck today and I was wondering if there would be any problems fitting it into my 100? I don’t think I’ve ever seen this deck on a 100, and just want to make sure there isn’t a reason.
Also, I understand these spindles are easy to rebuild. I wonder if anyone has any type of tutorial page outlining the details of rebuilding these spindles. Thanks a lot.
Old 04-14-2019, 10:21 PM
Tom Dowling Tom Dowling is offline
thirty years ago i fit a 44c to a 100 i used to have, if i recall you need parts from both wide and narrow lift frames and some modifications to make it work.
Old 04-14-2019, 11:12 PM
Thanks for the reply. I’ll start fiddling around and see what I need.
Old 04-16-2019, 09:46 AM
JLM78 JLM78 is offline
we put one under a 123 , had to re drill the deck hanger
Old 04-16-2019, 06:59 PM
That’s cool JLM. Still used the pin on subframe. Btw good seeing u post it’s been a while on and off.
Old 04-17-2019, 08:11 AM
mickb72 mickb72 is offline
That's cool. What pto belt did it take? I'm picking up a 44A Thursday and have a 100. Not what it's intended for, but. Mike
Old 04-17-2019, 08:50 AM
I bet it will cut real well, does it lift high enough?
