Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Kubota Engines
Old 03-29-2019, 06:12 PM
guyina4x4's Avatar
guyina4x4 guyina4x4 is offline
Default Fuel shut off solenoid wiring
well I got my D600 running a few months ago now and the warmer weather has me wishing the fuel shut off solenoid was hooked up.
so I made a bracket and wired it up
black wire to ground
white wire to "s" terminal on starter
red wire to ignition wire
when I try to start it the solenoid pulls in but soon as It starts and I let off the key it pops out and kills the engine.
isn't 12 volts to the red wire supposed to hold in the solenoid?
if I put 12 v directly to the red wire from the battery it doesn't hold it in either
any thoughts?
oh yea D600 swapped to 2084
JD x475
Old 03-30-2019, 10:43 AM
The Fuel Solenoid should only have one wire and the body is ground. That wire would go to the "R" terminal on the Ignition Switch.
I am "guessing" but it seems the White Wire should go to the R terminal.
Since I don't know what your D600 came out of, that is my best guestimate.
Old 03-30-2019, 12:46 PM
guyina4x4's Avatar
roland
thanks for the reply
it came out of a Jacobsen triking mower
I think I may have figured it out
I'll post back after I check it out
thanks
JD x475
