I believe that I have seen a post before on here about starting issues with the cyclops cubs but I am unable to find it with a search...
For some time now when turning the key to start, I only get a click. It may happen once, twice or several times before it actually turns over to start. My battery is good, no problems there. Where do I go from there? Switch or something else? Figured since my grass is all brown and I have some down time it would be good to get whatever is wrong repaired, gets old turning the key several times before it will turn over. Thanks.
Nathan Gardners, PA Cub Cadet Yanmar SC2400
The first place I would start is the Battery Cables. Make sure, that each cable is clean, bright, and tight on each end.
An intermittent electrical problem is hard to trace/find because you can't fix what is not broken @ the time. A starter solenoid, over years can and does corrode/ark internally as is the nature of it's operation and can cause that problem also. I don't think there is an easy way to correct the problem when it is not occurring, short of replacing everything in the starting circuit. Even worn brushes in a starter can cause that condition. As a long shot, when it acts up and just "clicks" hold the key in the start position for a while. then feel for a warm or hot connection in the starting circuit. it don't always work, but is about the only thing you can do short of replacing a lot of good components. It is nice if you have a donor/ similar tractor that you can substitute components with out having to buy them. |
Check the wire connections as described above. If that doesn't fix it, I recommend you take this route to fix your problem.
http://www.onlycubcadets.net/forum/s...ad.php?t=44607 |
This is a good write up by jimbob200521:
http://www.onlycubcadets.net/forum/s...ad.php?t=38545 PeterJ
1863 48" deck, 3pt 1864 x 2, 54" deck, power bagger, 48” deck 1811 44" deck 1210 44"deck IH trip plow QA42-A, 451 x 2, 551 42" Earthcavator Driveway Drag ![]() USAF Shepherd's Chapel |
I ordered my kit from Amazon and installed in about 10 min last night. Worked perfectly! Starts great each time. Thanks jimbob200521!
