Old 10-08-2014, 09:21 PM
chris hall's Avatar
chris hall chris hall is offline
Default 105 pto clutch
i have just a quick question about my 105's pto clutch. i have heard some rattling noises coming from this area. i am able to move the clutch a little side to side in the basket . i think this is the noise but, i am not sure how much movement is ok. the bearing is locked down and my set screws that hold the clutch to the bearing were tight.the clutch is working properly and the set screw on the pto basket is tight as well.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 10-08-2014, 09:30 PM
Do you have the anti rattle clips in place? Does the noise go away when you engage it?
Old 10-08-2014, 09:34 PM
darryljs's Avatar
darryljs darryljs is offline
Are the anti-rattle springs installed. Should be three of them between the disk and basket.
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 10-08-2014, 09:37 PM
chris hall's Avatar
oh .i didn't know there were rattle clips involved. you may have cured my problem. where do they go ? i am assuming the go between the basket and the fiber disc ?
Old 10-08-2014, 09:43 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
You may want to edit that post before the mods rip you a new one.
If you had , you would have realized that before asking the question. Sorry, just saying.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 10-08-2014, 09:45 PM
oh shit .i didn't know there were rattle clips involved. you may have cured my problem. where do they go ? i am assuming the go between the basket and the fiber disc ?
Shows one of three to the right of the red arrow. ( equally spaced )
Old 10-08-2014, 09:52 PM
chris hall's Avatar
once again guys thanks for the knowledge . sorry mod for the expletive.
Old 10-08-2014, 09:54 PM
darryljs's Avatar
Go here, tells you all you need to know about the PTO. http://cubfaq.com/mechanical_pto.html
Old 10-08-2014, 09:55 PM
chris hall's Avatar
i did the the rtfm. just a slip sorry shrew wont happen again.
Old 10-08-2014, 10:00 PM
chris hall's Avatar
thanks !!!!!!!!
