I'm sure many of you have seen the threads on some troubles with my machines I seem to have been having; the PTO dies on my 682 then comes back to life (well, for now), my 1050 has some foam in the oil (posting a thead in MTD/CCC subforum now on that), and a stripped out motor mount on my 1450. I need more time!
![]() Anywho, this time it's another 1450 problem. I fire it up the other night to move it and use it to jump another machine (don't ask ![]() ![]() ![]()
-Ryan
I'd do the fluid/filter change sooner rather than later.
X2....preventative maintenance goes a long way! It sounds like something is possibly clogging the filter and not allowing fluid to circulate.
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
Check the spirol pins in the driveshaft. Sounds like one sheared and is "catching".
Had the same problem with the 129 I'm working on for a guy. Ended up being a clogged filter. Do a fluid and filter change should fix ya up
No more cubs. But never fear there will be more ![]() ![]() ![]() ![]() |
I would bet on the sheared drive pin, like Jonathan said.
Well, I got a few minutes to check the 1450 out and I don't believe it's a sheered pin. I ran the tractor for a minute and saw the drive shaft spinning the input shaft to the hydro so I believe I'm good there. Now I just have to get the time and money between work and Christmas to buy some Hy-tran and a gasket
-Ryan
![]() Quote:
![]() Quote:
Edit: that would be about perfect if I could get away with that to get me by until spring. I've got enough hi Tran in the shop to top it off if I lose some but I don't have enough to do a full refill.
-Ryan
You will only loose a little that is in the filter and pump,the pump is higher than the fuid level.
