Old 05-24-2012, 05:50 PM
hondaxr hondaxr is offline
Default cub cadet 127 only 1 speed
I have a Cub Cadet 127 when I move the speed control lever (slowly) to go forward or even in reverse the tractor takes off fast and only goes 1 speed. I was wondering if there is an adjustment underneath the tractor to fix this problem? The hydro oil and filter have been changed recently.
Old 05-24-2012, 05:57 PM
Here's the link to the service manual it will cover the adjustments.
http://www.onlycubcadets.net/forum/s...ead.php?t=4643
Old 05-24-2012, 07:24 PM
You may also need to check the trunion.
Here is the repair link:
http://cubfaq.com/trunionrepair.html
Old 05-25-2012, 09:46 PM
gcbailey's Avatar
gcbailey gcbailey is offline
You made sure it is the correct filter for the transmission and not using an oil filter?
Gary
Old 05-29-2012, 05:12 PM
Yes, the filter is a Fleetguard HF6096. Thank You.
Old 05-29-2012, 05:53 PM
dirtdog dirtdog is offline
Default Cub cadet 127 hydro problem
I would check the hydro lever adjustment under the tower area. You pull the battery and then use either a crow foot or a wrench(1 and 1/16 or 1 and 1/8) tighten down until drag is just enough to hold lever . I had to make a wrench work by cutting it in half and grinding on it to fit. My cub was like a speed demon until i did this adjustment. What a difference it makes.
