Old 09-08-2009, 09:58 AM
Donzi Donzi is offline
Default New here, hello and a couple questions please
Hello guys,
I picked up a very clean 1862 with a kohler magnum 18 a few days ago.
425 hours on it. Looking to mow with it and take care of it. (also have a beautiful 1450 in the garage)
The governor will not adjust to function properly....I have tried per the kohler manual. Not sure if it is missing a spring, or the governor internals are bad.
Could someone post a picture of the 18 magnum governor linkage set up?
Also if it is the governor internals that are bad.....how horrible is it to replace?
Thanks
Ted
Old 09-08-2009, 11:08 AM
It's pretty horrible. The engine has to come completely apart. The gov is the first thing to go back in during reassembly.
Old 09-08-2009, 05:01 PM
aagitch's Avatar
aagitch aagitch is offline
can you be more specific. it may be something more simple than a governor gear
Old 09-08-2009, 08:41 PM
when I give the engine throttle, it will continue to rev up and up higher....too high.
When mowing, it bogs down and will not maintain RPM, I have to literally keep my hand on the throttle and constantly give it more or less to maintain RPM......unless I am on level groung and not mowing.
Old 09-08-2009, 08:45 PM
My 782 did this once, and it was because the throttle cable was horribly out of adjustment. I'd try that first. I can't remember off the top of my head which was I had to move the cable...I don't have the tractor in front of me, either.
Old 09-08-2009, 08:48 PM
Also, I did disconnect the throttle cable completely and ran the engine.
When I give it more throttle, it does not try to push back against my finger to reduce RPMS
