hydro fluid
what type of hydro fluid does the cc123 call for?
either "Hy-Tran" which is available at a Case IH Dealer or "Hydraulic Transmission Fluid" which is available at your cub dealer.
AJ |
10 degrees here in the north woods. should I run the hydro for a while before changing hydro fluid or just drain it regardless of the temp
It's always best to drain warm fluid, if it is possible.
I like to give it as long to drain as I possibly can, overnight being ideal. |
I also like to jack up the front of the tractor and get as much as possible out of the pump.
thx
thanx for the input guys. :biggrin2.gif:
fluid type
I was checking round town and found some fluid from NAPA #1410 hydro fluid. I also found #303 hydro fluid from O'Reilly. I just wondering whats been heard of these two and which would be the better of the two. thanx
I see you're in WI...I bet you have a CaseIH or Case dealer nearby from which to procure the real thing. We just discussed this at length in another thread.
http://www.onlycubcadets.net/forum/s...ead.php?t=7561 |
If you are in the Sheboygan County area, there is an impliment dealer in Waldo that carries Hy-Tran, also Madsons in St Nazianz has it in gallons and I believe in bulk.
| All times are GMT -4. The time now is 02:32 PM. |
