-   -   Battery backwards (https://www.onlycubcadets.net/forum/showthread.php?t=12726)
gcbailey 08-18-2011 08:22 AM
Originally Posted by Cub Cadet 123 (Post 87745)
Sounds like an error that others might wonder...."How did you make that mistake?", but I recently got a cub where a guy has installed two identical color battery cables and labeled the fender pan + and - (in pencil might I add:biggrin2:) to keep from mixing them up!!!! Hope whatever damage you have is minimal!!
somewhere along the lines the PO replaced the hot and ground wires on my O both with red wires and the same size ends.... no markings on mine though.
Matt G. 08-18-2011 05:04 PM
George-
None taken...I never claimed to be an EE...:HeeHee:
Wouldn't it matter if the condenser was on the wrong side of the coil? If you connected the battery backwards, the 'right' side would become the 'wrong' side, correct? Or doesn't that really matter?
ol'George 08-18-2011 08:50 PM
Originally Posted by Matt G. (Post 87870)
George-
The condenser will be on the points side of the coil to function correctly.
The system wiring would not be changed except the coil would be receiving reversed polarity, it will not affect the way the coil performs.
In the old days, the voltage regulator would usually burn the contact points, when the battery terminals were reversed.
Most distributor systems had the condenser mounted inside, some hung them outside, and still others mounted them on the coil but all connected to the point side of the circuit.
green 4 acres 08-19-2011 11:00 AM
Originally Posted by lmcclinton (Post 87792)
I do have a multimeter but am not the greatest at using it. Ha Ha. It's sorta embarassing but oh well. I have no idea how the heck I reversed the wires not to mention how my son was able to use it. I suppose I'll have to replace the battery to.
I would start checking ohm's with the points closed ( battery disconected) I pt filed my burnt points and still doing fine . reading should be just slightly lower than touching the meters leads together , but google using a muitimeter will help . points would be my guess or just a connection test ohm's of condenser ,coil and voltage this is a original CC right can't imagine what it would have damaged. reverse polarity is the destroyer of integrated circuits ,diodes ,triodes ,& board circuits & alike which you do not have on this model
AMCJavelin74 08-19-2011 09:09 PM
Originally Posted by ol'George (Post 87796)
No offence Matt,
Actually,
The coil can be hooked up either direction as well as the condenser, so no damage will occur to them.
Years ago many systems used a positive ground.
I would check to see if the voltage regulator is operating correctly, as they can be damaged by reversing polarity.
Chevrolet, in the early days, (when they had wooden floor boards/wheels) had a reversing switch in the ignition system that reversed the polarity of the coil/condenser/points with every start.
Research showed that doing so, increased point life by equally keeping the build up on the contact surfaces equal.
Neatest thing I learned so far in 2011.:biggrin2:
Rhoderman 08-21-2011 09:07 PM
I would think the condenser would possibly be polarity specific. Aren't they electrolytic? If it's swollen, it's probably not any good. That would appear as a short across the points at all times.
The only thing that could probably be damaged would be the regulator.
If it was running, and trying to charge the battery in reverse, and actually succeeded, your battery might be a goner.
To check the points, put your black meter lead on the chassis somewhere. Put the red lead on on the points side of the coil. Rotate the engine slowly by hand with the key on. You should see it change from 0V to 12V (or thereabouts) when the points open. Always 12 = no points in the circuit. Always 0 = shorted points or condenser, open coil, or no 12V on the other side of the coil.
Hope this helps.
And Matt, remember you can't spell geek without a double E. I knows this because I are one. :)
ol'George 08-21-2011 11:23 PM
Hope this helps.
The condensers are not electrolytic, they are paper wound and not polarity specific like in electronic circuitry. If the battery was dead and recharged with the wrong polarity, it would loose about 50% of it’s capacity to work and would soon become worthless.
I’m not familiar with originals, is there a fuse that is blown?
