Old 03-27-2011, 12:00 PM
william1041200's Avatar
Default 104 turning into 125
Here is my plan:
take my nice finished 104, add in a k301 and transfer hydro setup from 107 .
They are both narrow frames, and the dash from the 107 is good, but the steering tower is scrap on the 107 , so is the frame. I feel it would be a smooth transfer, and foresee no problems.
So do you guys know if I would run into a wall?
Old 03-27-2011, 09:29 PM
That ain't gonna work...
the hydro controls are different.You also have to change the release valve setup.How are you gonna stop it,the brake setup is different also.125 is internal and the 107 is a disc brake setup.
Check the parts manuals and see what I mean.
Old 03-27-2011, 10:41 PM
There were gear drive and hydro symmetrical frames and tunnel setups throughout all runs. My 104 has provisions in the steering tunnel upright for hydro controls. Also, in the side near fenders for the release valve handle. The 107 has a cover plate on the fender pan for a gear drive handle to come through. The 104 had internal brakes. 107 had external brakes. Both work off the same rockshaft. (I may be wrong there... I will see tomorrow, work permitting. ) If the rockshaft is different, I have the correct one from the 107...
Old 03-30-2011, 10:20 PM
OK here is some disassembly and comparison progress on the conversion:
pic 1 compared to pic 3 I need to drill 4 holes for vertical hydro control support.
Pic 2 is the dash tin from 107 to be transferred over
pic 4 is the 104 that is the new base frame of this conversion. Duals included, geardrive rear excluded. ha ha
pic 5 is the k301 engine going in after cleanup. turns over smooth, and oil looks good for sitting so long.
6 is inside view of 107's dash hydro control tensioner- What a MESS
7 - The 107 has a metal cooling fan! And its perfect!! What a Plus!!
8 - Need to change oil and filter!! I bet this is factory filter!
9 - What's this cutout in frame for? I have seen no useful reason to cut the 104 frame to match.
10 - distant view for relation to whole tractor of cutout.
File Type: jpg 107 dash tin and lever down (Mobile).JPG (25.3 KB, 473 views)
File Type: jpg messsy hydro control tensioner (Mobile).JPG (28.0 KB, 472 views)
File Type: jpg possibly factory oil filter 107 (Mobile).JPG (22.9 KB, 471 views)
File Type: jpg whats this cutout in frame (Mobile).JPG (25.1 KB, 474 views)
Old 03-30-2011, 11:35 PM
Tractor2nv's Avatar
Tractor2nv Tractor2nv is offline
Cut out on the frame(107) was for a inspection cover to get to the damper plate on the hydro...ah...not sure if the dash cowl will fit the tower on the 104 and the tower on the 107 is different from the tower on the 104. I did a conversion on a 125 to a manual shift. I'd say a little more easier than what you may/will go through...good look'n 104 rollin' dually!
File Type: jpg 26969_117382391607400_100000069192393_278068_955675_n (640x480).jpg (27.9 KB, 469 views)
Fool me once shame on you,fool me twice...shame on me!
Old 03-30-2011, 11:40 PM
Thanks for the compliment! Back to that inspection cover: What could you get to that was so special? I looked and looked , saw nothing servicable with the cutout. you can look and see the cam pin move. Is that it?
Old 04-03-2011, 03:41 PM
Default new pics of clean parts
spent most of today cleaning up old grease preserved parts. Boy , they were ugly! But, Look what I found!! Nice Clean hydro, and engine
And Finally, some last pics of the 104 assembled as most have seen it thus far.
Im headed back out to strip it down to frame rails. I have decided to use the 107 upright tunnel for now. The control handle will not give up. Im gonna feel real dumb in winter when it does come off and I dont want it to! I will be putting the set screw in it.
Old 04-03-2011, 05:03 PM
Love the duals, William! I have a question. Where did you get the rear tires? I need one set for my 100. Thanks!
Old 04-03-2011, 07:43 PM
Allen, I honestly don't remember! That was 2 years ago, now. I kinda think I just had the auto mechanic across the street order them and my tri ribs from his tire dealer. They are Carlisle tru Powers, and they like to eat dirt!
Old 04-03-2011, 10:58 PM
Thanks William! I already have one set on the 100. The other two are another brand. One of them is about to bust. So, I want matching tires...lol.
