Old 12-29-2010, 05:03 AM
cdlong's Avatar
cdlong cdlong is offline
Default Setting WOT
I read a post supported my Matt, (Are one stage blowers lame?), that all powered attachments, (mowers, tillers, snowthrowers,etc.), should be operated @ WOT. I think WOT on my 1450 is 3600 rpms, under load. What would I use to set WOT on a Kohler? I have a vibratach, but don't put much stock in it. Can't find a dwell meter, (am I showing my age!), for a single cylinder either.
Thanks for any help.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 12-29-2010, 07:17 AM
This is something you may consider......
Sendec............ http://www.sendec-products.com/
* Panel Mount
* Surface Mount
* Shop Meter
Old 12-29-2010, 10:02 AM
cub149's Avatar
cub149 cub149 is offline
I have been looking at the Tiny Tach. Are they good? Do the Kohlers in our 149s and 1450s have one spark per revolution or one spark per two revolutions?
Chip T.
Drexel NC
Old 12-29-2010, 07:44 PM
william1041200's Avatar
one spark every 2 revolutions. The points operate off the cam.
Old 12-29-2010, 08:14 PM
JayBrd's Avatar
JayBrd JayBrd is offline
Kirk Engines also makes an anolog tach that looks really nice also. I just wish it would work on a KT..
Here's the link: http://www.kirkengines.com/
Jay N.
Eau Claire, WI
RED 82 Series...
Old 12-30-2010, 12:32 AM
Iowa Farmboy Iowa Farmboy is offline
I saw the tech at the local small engine shop had a pocket tach that all he had to do was hold it within six inches of the plug wire. When I asked him where he got it he said it was a promo from Stihl as he is a dealer. He did not know where to get another. Any one else seen any thing like this before?
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
Old 12-30-2010, 04:46 AM
cdlong's Avatar
Thanks guys. A hunting I will go!
Papaw
Old 01-10-2011, 12:45 PM
cdlong's Avatar
Default Nice tach
Found these on Evil Bay. Not for K series, but they do work, (ya just have to double the RPMs). $14.45 + free shipping. Fits great between the gauges on the top left side of the dash.
http://cgi.ebay.com/ebaymotors/Digit...ltDomainQ5f100
Papaw
Old 01-10-2011, 01:43 PM
Dave R Dave R is offline
Default Using a Tach
Am I thinking this correctly?
If you use a Tach with the wire wound around the spark plug wire, you would want to set it for 1800 rpm? Firing every other turn of the piston would mean you are measing half the revolutions wouldn't it?
Dave
Old 01-10-2011, 03:04 PM
The tach will read correctly. We use them on my nephews racing karts. 4 stroke Briggs flat heads. When the tach reads 3600 rpms you are at WOT. We usually run right around 6000 rpms for the race motor.
