Old 09-30-2010, 02:38 PM
ihc353s's Avatar
ihc353s ihc353s is offline
Default Steering Column Problem, Cub Cadet "Original"
this Week, i wanted to remove the Steering Wheel of my "Original", i sprayed the Screw of the Shaft, with Rustspray, every day.
And now, i have a Problem, look at the Pics,
mfg Georg
I'm proud to be a German Cub Cadet 782 Owner!!!!
Old 09-30-2010, 05:46 PM
Georg,
I had that happen to me. Somehow you have to get that steering wheel off.The wheel that was on mine was trash so I used a long chisel and hit it off from the shaft between the steering tube and the wheel.If you are careful you may be able to reuse the wheel. Looks like you will be looking for a replacement Steering shaft.I am sure someone here may have or know a member who has one.
Old 09-30-2010, 09:14 PM
JayBrd's Avatar
JayBrd JayBrd is offline
3 prong gear puller will help you out. Had the same issue when I did mine, and it did the trick..
Jay N.
Eau Claire, WI
RED 82 Series...
Old 09-30-2010, 09:35 PM
Georg,
Matt G. had a really good post somewhere (I tried to find it but was unsuccessful) about removing the steering wheel without destroying the race bearing. Seems like he fabricated a wooden puller unit that didn't damage your steering wheel. I was able to just remove my acorn nut and with some effort pull my steering wheel off of my original, but I think that I got lucky. On my 73, I used a piece of wood on end and a deadblow hammer to tap it off without damaging my steering wheel, but that was after a week of soaking it with penetrating oil (PB Blaster). Still, took some effort though and if you aren't careful it might damage your steering wheel. I would recommend Matt's device that he made.....it seemed like the best option I've seen yet.
Old 09-30-2010, 09:49 PM
This thing...harmonic balancer puller and an oak block:
Old 09-30-2010, 09:52 PM
Thanks Matt. That's a picture worth saving!!!
Old 09-30-2010, 10:06 PM
A puller won't work on that.The threads are broke clean and flush with the wheel.Only George can tell us how he got it off.
Old 09-30-2010, 10:09 PM
I see about 1 1/2 threads sticking out. Since it's not one of the plastic-clad wheels, he can heat the hub with a torch until it glows, and then it should pop right off.
Old 09-30-2010, 10:15 PM
Matt,
Never though about heating it up.
Old 10-02-2010, 06:16 PM
ihc353s's Avatar
Thanks for the fast answers. Today, I got the Steering Wheel up from the shaft, with a puller, then, I disassembled the complete Tractor, and stored it in. I don't think, I will have time to work at it, before summer, next Year,
mfg Georg
