Old 09-11-2010, 06:11 PM
Bunky Bunky is offline
Question 1200 Lift Rod Removal ?
I have a 1200 that I want to take apart and redo as a stock puller, I'm having problems getting what appear to be roll pins out of the lift arm and the lift shaft underneath
Anyone have any suggestions ???
Old 09-11-2010, 07:14 PM
jeffscub's Avatar
jeffscub jeffscub is offline
purchase you some roll pin punches, PB blaster, and a hammer. soak the roll pins in PB every couple of hours or so for a few days. then take the correct size punch and give it a few good whacks till it is removed. thats how i removed mine!! hope that helps. jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 09-12-2010, 09:53 AM
Yurfriendtony Yurfriendtony is offline
Thats how I got my two off. A good quality punch the right size.
The latch rod inside both of my lift arms has been welded at the bottom. I am shopping for a good one should yours be in good condition and you willing to sale or trade.
Thanks, Tony
Old 09-12-2010, 01:25 PM
yardguy2 yardguy2 is offline
Default lift arm
I have been doing that now for a couple of days but no luck yet guess I will just keep trying. Thanks for the advise. I'll let you fellows know if and when I get it off. Ron
Old 09-12-2010, 06:14 PM
Smile One down 2 to go
Well I finally got the roll pin out of the lift arm and now working on the 2 inside the frame for the arms, The one that came out of the lift arm looked to be 2 roll pins in one...
Yurfriendtony If My arm is good I will let you know ..
I'm going to look for a roll pin punch tomm...
