Old 07-09-2017, 07:31 AM
sorner's Avatar
sorner sorner is offline
Default The multi tractor combination project I am only doing once
Well, I tried to shoehorn this Kohler CH18 into a engineless 149, and then I came across most of a 682. So I've decided to build a tractor out of all these partial tractors I have sitting around, just to do it. It will look like a 782 when done. I have a 1641 frame that I installed the CH18 engine into, the cast iron rear from the 149, and the dash (and soon to be fenders and hood) and steering box and steering wheel from the 682, and the hydraulic spool from the 149, custom bent and custom flare fittings reusing pluming from the 1641 and the nuts from the 149 pipes, a 1641 lift cylinder, and a 1641 axle. Oh and part of a driveshaft and the wiring harness (modified) from a 2185. Here are couple picture previews of the this project.
"One piece at a time... it's a 149 682 782 1641 2185....".
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
IH Cub Original with deck
GREEN 317 with integral sleeve hitch, front hydraulic
Old 07-09-2017, 07:46 AM
chief915ky's Avatar
chief915ky chief915ky is offline
Cool idea..... "The Frankentractor"
1974 Allis Chalmers 712S
1955 Allis-Chalmers WD45
Old 07-09-2017, 07:59 AM
clay1811/44c's Avatar
clay1811/44c clay1811/44c is offline
Maybe "Cubenstein". Make sure you look at Zippy's 2372 driveshaft issue so you don't have problems. Keep us posted
Old 07-09-2017, 09:02 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
1- 1200 in pieces
1- 1864 in pieces
Old 07-09-2017, 10:15 AM
DeltaCub's Avatar
DeltaCub DeltaCub is offline
https://www.youtube.com/watch?v=ws-_syszg84
Don't forget the Cadillac emblem....
Queen Of The Quietlines!
Old 07-09-2017, 11:38 AM
sorner's Avatar
oh yes I have seen it, duly noted
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-09-2017, 06:51 PM
sorner's Avatar
Awesome!!!
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-09-2017, 08:40 PM
You might as well blow apart the 1641 rear end and use the fine spline axles and carrier in the 149 rear end to beef it up while your at it!
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 07-09-2017, 08:54 PM
sorner's Avatar
Randy
Good idea, what's in there now? It's a 682 rear end not a 1641.
I've been wondering... Why is fine spine better as far as pulling?
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
Old 07-09-2017, 08:58 PM
sorner's Avatar
It's starting to look like a tractor.
And the 682 engine was donated to another member's 682 tractor this morning for a pretty decent shape IH #2 dump cart.
1872 with 50C deck
1862 with 50C deck
1641 with 48GT deck
364 snow blower
