Old 05-01-2017, 08:31 PM
Jbo_c Jbo_c is offline
Default Cadet 1641 charging/voltage regulator help
I have a 1641 that is not charging. Have 29.8vac coming off the stator.
The regulator is new(aftermarket). When I connect to the red off the regulator and the frame, I get 0.0-0.1 dc volts. I believe I should be getting 13(ish), right?
I realize it's possible I got a bad regulator, but it does seem highly unlikely. Is there something besides the regulator I should check into?
Thanks.
Jbo
Old 05-02-2017, 04:16 AM
Rectifier/regulator has to have a good ground or it won't work.
Old 05-02-2017, 05:33 AM
AS A TEST....
Take a long jumper wire and connect one end to the Battery Negative ( - ) terminal. With the engine running at WOT, touch the other end of the jumper wire to the Voltage Rectifier/Regulator case (or housing) and see if your system starts to charge.
* If it does, you have a grounding issue.
* If it does not, you have a bad V/R.
Old 05-02-2017, 06:11 AM
Will try this test hopefully this evening. But the body of the regulator it metal and it's bolted in, don't really see how it can not be grounded.
Thanks for the help. I'll let you know.
Jbo
Old 05-02-2017, 09:12 AM
farmall fred's Avatar
farmall fred farmall fred is online now
One other thing to check, unplug regulator with engine off, turn key on and check to see if you have same voltage as battery on the center terminal of the regulator plug in. Might have an issue with wiring or a bad ignition switch. My 1650 would not charge and it was a ignition switch that was corroded not allowing current to pass through. Get a copy of the wiring diagram and trace the wiring from the regulator to the battery positive and check at each connection.
Here is a wiring diagram copy. If you want a bigger copy do a google search for cub cadet 1641 wire diagram.
Hope this helps.
Tom
Old 05-02-2017, 11:35 AM
My regulator has two connections on one side(stator) and one on the other. Which one is the 'middle'?
Jbo
Old 05-02-2017, 11:52 AM
sorner's Avatar
sorner sorner is offline
Thanks.
Jbo
I have a lot of experience messing with Vanguard engines. This might be a dumb question (forgive me if it is), because I've done this myself before by accident and I have an electronics engineering technology degree... Did you make sure to switch your meter from AC to DC? I've done this accidentally more than once and was confused by the results before I realized I forgot to switch. If not, and it is still set to AC checking a DC line, you might see 0-.1 volts because of AC ripple getting through the regulator on the DC. Otherwise, there is nothing else but a defective regulator or faulty grounding getting in your way on this engine that I'm aware of. The alternator plugs directly into the regulator, so I don't think the ignition switch would be involved.
Old 05-02-2017, 11:54 AM
Well, sure, but Farmall referenced the 'middle' connection. ??
Old 05-02-2017, 11:57 AM
An EXCELLENT point sorner. I think I changed it, but would not be surprised if I didn't. Will verify test when I get home.
Jbo
Old 05-02-2017, 12:51 PM
Terry C's Avatar
Terry C Terry C is offline
On many/most it is the middle connector that is 12v.
Just make sure it's not one of the two going to the stator.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
