Greg Rozar AKA- CubDieselFan
Go Back   Only Cub Cadets > Off Topic > Suggestion box
Old 07-11-2016, 10:33 PM
RedOnes's Avatar
RedOnes RedOnes is offline
Default Which Forum Section
The forum is well thought out and constructed and most all of the sections are easy to understand. The most confusing thing for noobs and even some honest older members is to decide if a tractor should be posted in the IH or CCC/Mtd or LT sections. Yes, the mods can deal with it but I would suggest that a folder be created directly under the CUBCADETS forum heading entitled (IH Cub or CCC/MTD Cub or LT). Within that folder would be a locked thread with information that is presently linked in an obscure location. Such as the following...
...and any additional helpful info.
Frank
IH 982 , 3 point
CCC 782
Old 07-11-2016, 10:37 PM
I don't think it's confusing. All the IH built Cub Cadets said IH or International on them somewhere. The only series that is an issue is the '82 series. Some were made by IH and some were made by MTD. No one is going to jab you that hard if you put that series in the wrong section as they are basically the same not matter who made them. Subtle differences is all. Any tractor made before the '82 series is IH.
If it's shaft drive, it's a GT. If it's belt drive, it's a LT.
Old 07-11-2016, 10:55 PM
RedOnes's Avatar
Jonathan thanks for your very quick response
I cant even get help from 911 that fast ...
Frank
IH 982 , 3 point
CCC 782
Old 07-12-2016, 07:00 AM
Frank:
Jonathon is right. The only series that bears confusion is the 82 Series. It was the "transitional" series. It started out at the tail end of IH's ownership, then transitioned into CCC/MTD. Another solid tell tale distinction is the Serial Numbers. If it is <699,999 it is IH. If it is 700,000>, it is CCC/MTD built.
We (Admin Team) don't really jump on anyone for posting in the wrong section. We are aware of this confusion. We just simply move it to the right spot. That way, it gets the best exposure and the greater likelihood of the correct answer(s).
But thanks for the suggestion.
Roland Bedell
Buy: Made in the USA
Old 07-12-2016, 09:26 AM
RedOnes's Avatar
well, in that case, I refuse to take this matter to a higher authority. Seriously guys, thanks for providing and maintaining a fine forum ...
Frank
IH 982 , 3 point
CCC 782
