Old 05-18-2010, 04:41 PM
labrati labrati is offline
Default PTO "guide"
Does anyone know where to get that little wing shaped PTO install guide that fits over the wear button and the throw out plates to properly adjust?
Also, anyone know of a source for the anti-rattle springs? Local Cub dealer couldn't find a reference or part number for them.
thanks
Old 05-18-2010, 04:55 PM
I beleive R Bedell recently posted the dimensions of the adjustment guide in a PTO post....normally when you buy the kit it comes with the kit.
Old 05-18-2010, 06:10 PM
Click on this link for Mech PTO Data...... PTO
Which PTO Clutch are you working on....NF or WF...??
Parts are available from your local CC Dealer or the fine Sponsors above.
Old 05-18-2010, 08:44 PM
wshytle wshytle is offline
Roland-
If it's the same pto he posted pictures of in another post it's a narrow frame pto.
Labrati-
The sponsors above can get you all the anti-rattle springs you need. They work well but they'll also be the first part missing from the pto after several hours of operation. You also need to install them AS you slide the pto into the basket and over the bearing, not afterwards. You'll see what I mean when the time comes.
Old 05-18-2010, 09:00 PM
NF PTO Gauge.....
Old 05-24-2010, 12:21 AM
rpking rpking is offline
I just rebuilt the PTO on my 100 and the kit part# 759-3490 came with the anti-rattle springs and the adjustment gauge.
Old 05-24-2010, 06:35 PM
gcbailey's Avatar
gcbailey gcbailey is offline
Why does the manual say if you are not using a piece of equipment with the front PTO to leave it engaged? So it's OK with a mower deck to engage and disengage constantly, but otherwise leave it engaged? My 127 I just got is the first tractor I've had with a mechanical PTO, so this is all new to me....
Gary
Old 05-24-2010, 07:00 PM
When it's engaged, no wear is occurring on either the friction disc or the thrust button. It's just sitting there spinning. When it's engaged, the friction disc rotates inside the clutch, and the slight drag from this slowly spins the clutch when there is not a belt on it, which wears the thrust button.
Old 05-25-2010, 12:50 AM
CMA's129's Avatar
CMA's129 CMA's129 is offline
This place sells just the adjusting gauge and the springs seperatly.
http://ccspecialties.org/ptocreepers.html
