![]() ![]() My cub cadet was running fine and it started to sound like it was running out of gas and quit. I discovered I had no fire at the plug tip. Now I had just put in a new plug for the start of the new mowing season a day earlier. I've narrowed it down to what I think is the coil or the black box that's wired to the coil that mounts on the outside of the motor and close to it. I have also noticed that the one relay closest to the coil isn't clicking either. However I do know the relay is good. What's everyone's thoughts on what my problem could be or what I should do to next? Thanks |
Welcome to the forum!
How about we start with what model you are working on.... "2000 series" is a little vague. ![]() |
![]() Quote:
My apology guys. It's a 2166 model with a 16 horse Kohler engine. Thanks.
Your engine has the infamous SAM ignition. That's the black box mounted on the out side of the blower housing. Here is a link to the service manual for the engine.
http://www.kohlerengines.com/onlinec.../tp_2402_a.pdf This link will take you to a list of Cub electrical diagrams, click on 2000 series then click on 2166 and you will get the diagram for your tractor. http://www.ihcubcadet.com/diagrams/E...Schematics.pdf
Hey guys, thanks for the valuable info and direction. It's much appreciated!!!
I can help with a fix for the ignition system. It involves removal of the SAM and replacement of the coil. I have done it to my 2166 and it works. If you search this site, there is an older thread that deals with this subject. I'll post this evening with a Kohler part number and some instructions.
Wes Thompson |
I lifted this from an old post. It works. The white wire will be your "kill wire". The new coil will have only 1 terminal on it.
The plug wire is just long enough to work. You'll want to take a piece of 1/4" fuel line and split it. Put it over the tin to protect the plug wire. http://www.onlycubcadets.net/forum/s...2&postcount=14 This is the coil that I used. Less than $30. Kohler P/N 20 584 03-S. It fits a 20hp Kohler Courage. I bought my coil off of Amazon. |
Sorry for the late reply......Been doing something I dont care for, Push mowing all my yards. lol This is great news, but I have a question? I dont have a white wire going to my existing coil. I have a yellow, brown and black for the ground on the side of the coil and what do I do with the remaining wires from the SAM box ? Thanks.
![]() Quote:
