Old 05-02-2015, 06:47 PM
CubDieselFan's Avatar
Default 1864 Troubles
I mowed part of my yard today and shut it down to look at snake I just hit. Chicken snake by the way. It sat about 20 minutes and then would not start. Finally got it to start and it did not have any power. I checked it and the right side has no fire so it looks like I get to pull the engine to replace the ignition module. Any advice before I do that? Thanks for any info in advance. 615 hours on the engine.
More info: Inside the boot is rusty and the right side is new, so looks like the PO changed the left side and not the right.
Old 05-02-2015, 09:05 PM
So, what is your question?
Old 05-02-2015, 09:38 PM
I was asking is there anything I am missing? I am thinking my next step is pulling the engine to replace the Ignition module. Measure twice, cut once. Never harts to ask.
Old 05-02-2015, 09:50 PM
Well you could rule out a bad plug by replacing it with a known good one.
Old 05-02-2015, 09:52 PM
Yep, I did that, still would not fire. I was hoping it was the plug.
Old 05-02-2015, 10:07 PM
close the gap up to about .015,--- if it fires, pretty much a bad coil.
Had one that will fire up cold, and run all day.
But shut it down to get a drink of water and it refused to spark/start till stone cold.
Don't know about your motor, but on a M-18 in my 782 I didn't pull the motor just the shrouding.
Might have been just as easy to pull the motor tho'
Old 05-02-2015, 10:33 PM
It's easier to pull the motor.
Could be the kill wire. That wire is known to get damaged and ground to the block. I'd disassemble before ordering a coil.
Old 05-03-2015, 09:09 AM
Thanks, I was thinking it would be easier to pull it. I will pull it next weekend.
Old 05-03-2015, 09:25 AM
It is always better to diagnose and trace down the issue rather than "shot gunning" it with parts.
Old 05-03-2015, 09:35 AM
I will agree. I am going to pull the engine and see what the issue could be. Like Jon said it could be a loose wire. Thanks for the input everyone.
