Old 04-25-2015, 05:40 PM
jimbob200521's Avatar
Default How to: Install Starter/Solenoid Relay for Kohler Commands
Have a Kohler Command in your 1864, 2084, 2284, etc? Ever get the random "click" when you try to start it? Then this article is for you!
Brief History/Explanation
This issue can be caused by several things. First, our machines are now getting 20+ years old and through time, nature has taken its course. Connections weaken, corrosion occurs, and weak signal become present. Multiplied by the fact that our Cyclops Cubs have many safety switches between you turning the key and the tractor starting, this issue is often amplified. Also making this issue worse is a weak battery or a battery in the dead of winter not giving you its full 12.2+ volts. What happens is when you turn the key switch, the signal must travel from your key switch through several (often corroded) safety switches, many feet of wire, and finally to your starter/solenoid. This requires your battery to be at its best, which often times it may not be. By the time the voltage gets to your solenoid, it may only be 11 or even 10 volts, not always enough to do the trick. Installing this relay takes the load off of your key switch and gets you better starting capability.
Parts & Tools Required
This is a very simple procedure to install, and as such, you don't need many tools. I used the following:
Relay kit MM510 from Farm & Fleet (this also came with all the wiring and fuses I needed)
Socket wrench to connect the ground
Socket wrench to connect the positive to the battery
Wire strippers
How to
Let's get down to it. First off, I want to show you a picture of the kit I purchased. This rang in at the grand price of $8.99 + tax, so not exactly a bank breaker.
Next, a picture of how this is wired up. This is fairly simple so make sure to read it and read it again so no wires get crossed. Crossed wires are a big no no! Also, please note: I color coded this diagram to the wires I chose to use. If you want to use different wires, a different fuse, different colors, whatever, feel free. This is just what I used.
Open the kit and familiarize yourself with what's included. There are a few parts not needed (wires and the switch) so toss those in your "I'll use these later...for...something" box that we all know we have.
First, safety: Disconnect your battery so we don't have any unwanted sparks.
Next, I started by mounting the relay to the blower shroud and running the ground (yellow in my case) back to the mounting screw. Simple and clean. One down, 3 to go.
Remove the blue wire from your solenoid and connect it to the 86 connector on the relay. 2 down, 2 to go.
Run a wire (I used green) from 87 to the connector on the solenoid you just removed. 1 more to go.
Now run a FUSED wire from 30 to a constant 12v. I used the included 15 amp fuse.
Now, double and triple check your wires and when you are comfortable with the connections, reconnect your battery. Take a seat and turn your key switch to a now click free engine.
I'll post a couple pics of my setup installed. I hope this is able to help some guys out there with this issue, I know I'm happy with the $10 and 20 minutes spent doing this. Enjoy guys!
-Ryan
Old 04-25-2015, 06:15 PM
Good write up my friend.
Old 04-25-2015, 07:06 PM
Thanks Sam
-Ryan
Old 04-25-2015, 10:17 PM
CubDieselFan's Avatar
My 1863 does this. Thanks for the info.
Old 04-25-2015, 10:41 PM
EricR's Avatar
EricR EricR is offline
Great job Ryan!!
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 04-25-2015, 11:21 PM
Why didn't you shorten your wires up?
Old 04-26-2015, 12:23 AM
That's all ya got to say?!
Limited time and I was out of crimp quick connects is why at this point . I'll tidy it up later
-Ryan
Old 04-26-2015, 01:45 AM
I copied Ryan's first post and added it to the Technical section. It's under the sub heading "Tech Tips" in the tractor section.
http://www.onlycubcadets.net/forum/f...splay.php?f=59
As a note, I did make one change to the post. The fuse that you used (15A) is plenty large enough. No need to "upgrade" it to a 30A. If the solenoid ever pulled 30A you'd be in big trouble as the winding's inside it would burn first. So I left that part off.
Nice write up Ryan!
Old 04-26-2015, 02:09 AM
Nice write up Ryan!
Good to know and thanks bud
I write the couple how-to's that I've done (all two of them ) in hopes that I can give something back to the forum that's give so much to me any my hobby. Enjoy guys, I hope it can help some members out there
I've also edited the OP in this one to reflect the 15 vs 30 amp fuse change.
-Ryan
Old 11-20-2016, 01:28 PM
1250LC's Avatar
1250LC 1250LC is offline
Default Same thing only different
Had to smile when I saw this. I rigged up something nearly identical on a NH TC33D a few years back - I also have an IHC CC 1250 I inherited from dad. I used a pushbutton supplied with power from the key switch. That way I have the OEM key switch operation or can choose the pushbutton which bypasses the safeties (oops - did I say that). That way the pushbutton won't work unless the key switch is on.
