Old 02-25-2015, 09:54 PM
Ikea6e Ikea6e is offline
Default 1862 Foot Control
Foot Control Pedal on one of my 1862s.
If the tractor wants to creep in neutral (brake pedal depressed), fix that problem prior to starting this project.
The hydro control cross shaft needs to come out. It’s much easier to get out if the handle is removed first. Plus the rivet holes are used to mount a bracket.
Drill a ¼ inch hole as shown 1 inch above the existing hole on the other end of the cross shaft.
Cross shaft with bracket attached.
Cross shaft re-installed. A grease fitting was added to help keep the original Hydro control linkage working smoothly. Less work for the return to neutral (RTN) spring to do.
Outer bushing (1/2 inch bronze ID) for the foot pedal.
Inner bushing installed in the lift cylinder bracket.
Pedal assembly.
Collars position the pedal in the frame. The one on the right gets a bracket welded to it.
Pieces needed, less foot pedal.
Inside collar with bracket welded on.
Adjustable rod, transfers foot pedal motion to the cross shaft.
Damper attached to bracket on foot pedal shaft.
Other end of the damper attached to the battery tray.
Cub Cadet 2185 RTN device and bracket.
RTN bracket cut to fit under battery tray.
Bracket attached to the left side of the tower, under the battery tray.
The opening for the hydro linkage to pass through the tower needs to be enlarged to clear the RTN heim joint. (Not necessary on my 1864.)
RTN adjusting rod attached to the cross shaft. With the tractor in neutral (brake depressed) this rod should be adjusted so that the RTN is also in the neutral position as shown.
Shows why the opening needed enlarged.
Ready to operate.
I have an 1864 I picked up last fall; I may try to figure out a way to change where the pedal assembly comes through the frame. Drilling a ¾ inch hole through the lift cylinder bracket is a pain.
Old 02-25-2015, 10:29 PM
gt383mag's Avatar
gt383mag gt383mag is offline
very cool setup thanks for sharing
Old 02-25-2015, 11:45 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Thanks for sharing, Ike! Excellent write-up again.
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 02-26-2015, 10:41 AM
Your welcome guys.
Hope it is helpful.
Take care,
Ike
Old 02-26-2015, 10:52 AM
garrynok's Avatar
garrynok garrynok is offline
As others have said, great write up and documentation! Thanks for sharing.
Curious about the damper, what did it come off of and does it make a lot of difference?
I've got a 782 I want to convert this spring. You've given me lots of ideas between this write up and the one on your 1811. When I had my 782 apart I drilled the rivets out of the shift arm and made a bracket. I'm leaning on using a foot bracket like on your 1811, surface mounting a return to neutral just behind the rear fender, then a rod from the rtn, under the driveshaft cover to the bracket on the shift arm. I made a mockup while I had it apart. I just don't want to use a damper unless I have to.
Thanks again for the ideas!
Garry
Old 02-26-2015, 11:21 AM
PGHsteelworker's Avatar
PGHsteelworker PGHsteelworker is offline
I have to agree with everyone, nice job and write up.
Old 02-26-2015, 02:04 PM
What they all said. I'd like to come up with a way to do that on a Super. Big problem is the extra brake peddles in the way.
Old 02-26-2015, 05:50 PM
Garry,
The damper came off a 2185. I also got one off Rich Patton a few years ago. They are on most Tractors with a foot control. If you have smooth ground you may get away without one. Snug up the friction control a little. If your ground is on the rough side it can get your foot bouncing, resulting in a jerky ride.
I put a foot control on a 782 a few years ago with a pedal like on the 1862. Instead of a cable like on the 1811 ( https://www.onlycubcadets.net/forum/...ad.php?t=37377) I ran a shaft from the pedal behind the steering box, put a bracket on the end of the shaft with a rod up to a bracket on the shift arm similar to the one on the 1811.
Old 02-26-2015, 05:55 PM
Thank you,
Ike
Old 02-26-2015, 06:03 PM
Sam,
Never had a super, so I don't know if the differential braking would be a big deal to me or not. My loss from what everyone has to say the supers are great.
Take care,
Ike
