I put yellow arrows pointing to all 4 as reference, I only need to know about the rockshaft ones, thanks again.DSC02332.5JPG2.jpg
yup the 2 upper ones in photo are the rockshaft...just use an appropriate size punch and hammer. never removed that style of rockshaft before but heard your in for a rough time as the peices dont like to slide on the shafts. it will help if you can remove paint from the shaft so the arms can slide
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
You are going to need some punches. I got both sets from Harbor freight when I dissasembled a 125. Sometimes you need a short one, sometimes a long. The $18 for both sets was well spent.
Just so we don't get too deep into tools..... she stated in her last thread that she has roll pin punches.
![]() Yep, rockshaft is the top one in the pic. |
Now that you mentioned that, I read through that thread and indeed she did say she has many tools from her late Husband.
THANKS..now..do I approach these pins from the side that shows in the pic, or from the other side? I am not dumb, just have not done some of these things yet. I learn by doing.....and asking questions
You can drive them out from either side. Want to drive them from the side you can get the best swing from a hammer. I'd go from the pic side if it were me. They still can be a pain to get out. Also check to make sure a PO didn't hit on one end with a hammer or punch. May have mushroomed that end and it will be hard to drive through the rockshaft. Good luck and keep us posted.
Josh Diesel Cub Cadets........... |
Thanks, and I will keep you posted.
If you can, you may want to grind/file the end flush w/the shaft.
That way as soon as it starts to move you can get some WD-40 or something like that in there to help loosen it and also avoid mushrooming the end. The correct punch will follow it right through the shaft. I assume you are going to replace them anyway w/new ones. BTW. why are we/you removing them ?? Be carefull!! |
Thanks. I am removing them in order to replace the rockshaft assembly.
I lost lift last year after I attached the 451 thrower to the 982. Apparently I either attached it incorrectly or the pins were ready to let go and just needed that straw that broke the camels back. I have lift action under no load, with load, my blade, I am lucky to see 1" on the R side , and 1/2" on the left. |
