Old 11-03-2014, 09:29 PM
darryljs's Avatar
darryljs darryljs is offline
Default 125 Weight Bar/Aux. Battery Holder
I needed a weight bar and a holder for an auxiliary battery to operate a winch for a future idea/project. I came up with this, which will also use an adjustable ball hitch for towing log skidder, log splitter, log lifter, small trailer, etc..
Patience is the key to success . The difficult, I'll do today . The impossible, I'll do tomorrow
Old 11-04-2014, 05:58 AM
dbuck dbuck is offline
Very nice job,
Don B, USAF 1962-1968, Ft. Wayne, IN
Old 11-04-2014, 07:48 AM
chris hall's Avatar
chris hall chris hall is offline
great work. do you have some pics of the way it mounts ?
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 11-04-2014, 07:59 AM
darryljs's Avatar
Look at the first pic and just behind the battery you can see 2 3/8" bolts through the frame above the axle. There's another bolt above you can"t see between the 2 . Thanks for the compliments guys.
Old 11-04-2014, 09:00 AM
Well done
Old 11-04-2014, 09:04 AM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
Looks good and innovative too.
I never seen a 12v battery quite like that one before. Must be for use in battery banks or commercial UPS, etc. ?
Old 11-04-2014, 11:30 PM
darryljs's Avatar
It's a deep cycle 120 amp reserve capacity battery 575 cca. Can use it to power winches or hook up a 2000 watt inverter to get 120volt ac power out in the wild or emergency power in case of a power outage. I have plans on putting an alternator hookup to charge it. Alternator will hook to the pto so it will be able to be removed as necessary (as soon as I get time to figure it out and install it . Thanks everybody for the compliments.
A couple pics of adjustable hitch.
Old 01-10-2015, 08:47 PM
chris hall's Avatar
I cant wait to see that.
Old 01-11-2015, 10:43 AM
IHinIN IHinIN is offline
Nice work.
I noticed that there is no bracing to keep it from flexing side-to-side. When you are pulling something and turning it looks like it could flex and possibly damage the battery. Maybe not an issue but I'd hate for you to crack the battery case and get acid on your nice paint.
Old 01-16-2015, 11:57 AM
cubfan's Avatar
cubfan cubfan is offline
Very nice!
