just cut the sprocket out and installing it tonight hopefully it'll work
Hello and welcome! Could we get a pic of what you did? Me personally I wouldn't do that. You would be better off buying the correct part.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Well it works great for now engages and disengages fine and it doesn't slip1411924448334.jpg
I could see it being a temp fix and good thinkin on yer feet. But for as cheap as a jew clutch disk is id be swapping it out soon. So much more smooth in taking off and if u need it to slip it will but new parts will hold just as good
No more cubs. But never fear there will be more ![]() ![]() ![]()
I agree with cubby, you'd be better off fixing it the right way. Get the correct parts and fix it right. There are some things you can modify to fix like I have a older k301 and a newer pto clutch. It has a bronze sleeve on it and a oversized key way , but I'm your fix may tear up more than what it would cost to fix it right. My 2 cents
I got the idea from a web site on pulling tractors and if it would work for them it would work for me in the yard pulling a plow (NOTE: If an aluminum clutch disc is used in a high rpm tractor, I found they won't work as well because after a while the aluminum will get galled, and the clutch could become "grabby." The aluminum disc works best in a stock tractor with the engine running at a maximum of 4,000 rpm. Therefore, a double fiber clutch disc set up with a cultivator pressure spring may to be installed.)
I wouldn't run an aluminum clutch even in a pulling tractor. (Yes, I am very aware that they sell them as an option.) Sounds like your convinced though, so whatever. It's yours, do as you wish.
I'm not trying to be argumentative over the deal I just did what I could do to keep my machine running until the first of the month when I get my VA check and I might have the cash to buy regular clutch I'm very aware of the detrimental aspect of metal on metal I was raised different but I do what I can do
Desperation, the mother invention. Do what you have to, to get-er done!
Steve |
I like it. make it work!
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't! 72 scout IH 404 tractor |
