Old 03-18-2010, 10:51 PM
Default Cat 0 / IH tiller adapter
I decided to start reverse-engineering the Cat-0 tiller adapter for the IH tillers. Here's what I've got so far...just need to finish weld and paint these. I'm running out of spring break, so I'll need to attach the tiller to the gearbox next time, and come up with a way to lift it with the Cat-0 lift. I really like how the gearbox goes on and off in 30 seconds with this.
Old 03-18-2010, 10:55 PM
Iluvtruks0's Avatar
I cant see your pics. Sounds good though!!
David in NC
Old 03-18-2010, 11:08 PM
Great job, Matt!
Old 06-23-2010, 07:33 PM
I'm now mostly finished with this project I started when I was home for spring break. This is a seemingly rare IH tiller adapter to allow the IH tillers to be used on the 82 series tractors with Cat-0 hitches. I worked off of one small picture of the actual kit. I now need to get a belt and set up a mule drive and I'll be tilling with the diesel.
Does anybody have any documentation about the actual kit? I have never seen anything anywhere other than one picture and caption in Hank Will's book. I saw one in person many years ago, before I knew what it was.
Old 06-23-2010, 10:03 PM
john k's Avatar
john k john k is offline
Matt, this is the first time i saw this post. I have one that came with a tiller i bought and if i get time after red power i will take some pictures and measurements for you and post them. john
Old 06-23-2010, 10:36 PM
jbollis's Avatar
jbollis jbollis is offline
MATT,
I really like your setup. But there are 2 areas that concern me. First of all don't take this the wrong way. I am in no way knocking your work. I have learned to build and brace for the unexpected.
I would try to get a bolt or two into the bar that goes into the top link connect. I would go from the gear box side and just tap into the bar you made. This would help keep the gear box mount from trying to pull away from your made bracket, as your bolts are down low.
Then I would make a pair of supports from the side of the gear box mount running rite to the pins for the lower 3 point arms. This would definitely help with any unexpected side load or twist, from hitting rocks, roots, or whatever. It also would not hurt to put 2 more square blocks towards the middle of your (hinge) on your made bracket, clearance allowing that is.
Again don't take these suggestions the wrong way. I tend to over build things, but they don't break.
JOE
Sold everything but one.
Old 06-23-2010, 10:38 PM
jbollis's Avatar
Originally Posted by jbollis View Post
MATT,
JOE
Sorry I just looked closer at the one picture and see you already did this.
Old 06-23-2010, 10:53 PM
ihnick's Avatar
ihnick ihnick is offline
man i love the looks of that tractor
Nick.
Old 06-23-2010, 11:02 PM
jbollis-
The gearbox mount I made is stronger than the OEM one was...I think it only had 3 bolts holding the box to the bracket. Mine has 4 bolts and a larger plate. I can't easily tie into the pins for the lower arms. My 3-point plate is tweaked a bit, and one of the pins is no longer orthogonal to the plate. I don't want to know how the PO bent that. The rest of that hinge is pretty rigid. I'm not sure adding another hook is going to do anything. The two plates butt against each other when it is assembled. I'll see how it holds up, I guess. This is basically just as the OEM version of this kit was, with a slightly larger gearbox mount. Thanks for the input though
Old 06-24-2010, 06:41 AM
Good job Matt
