Old 08-20-2014, 11:28 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
Default 1863 with 48"GT deck. Belt too long
The belt on my 1863 with 317-48" deck broke. I ordered a 5/8 x 92" replacement belt but it is to long. I measured the old belt this morning at 88". I took the old belt to my cub dealer this morning and he said the 5/8x92 belt is what it calls for. The 88" belt has been on it since I got the tractor and has worked OK. Something must be screwed up about the deck attachment but I have no idea what. Picture of the mule drive pulleys almost rubbing with the 92 inch belt installed.
Cannon
Old 08-20-2014, 11:41 AM
Cannon51's Avatar
Don't know what happened to the picture.
Cannon
Old 08-20-2014, 01:19 PM
According to the Cub Cadet parts look-up site, it calls for a 954-3001 Belt, which is a Section B x 91.68" long (or 5/8" x 92").
A better picture of the Mule Drive Assembly would be most helpful.
Old 08-20-2014, 02:41 PM
Cannon51's Avatar
I made some more pictures but it's so humid here the lens kept fogging up. I don't have a lot of room between the back of the deck and the wheels, maybe 2 inches. I figure I would need to go back at least an inch to get close to the belt adjustment notches. I was hoping this was a common problem. Does anything affect the front and rear position of the deck other than the hanger to mule drive attachment point?
Cannon
Old 08-20-2014, 02:51 PM
I was hoping for a better shot (or wider angle) of the top picture. I suspect the arms to the Mule Drive maybe mounted in the wrong spot.
Old 08-20-2014, 04:10 PM
Cannon51's Avatar
I believe this is the hole the 317 owners manual shows.
Cannon
Old 08-20-2014, 05:04 PM
Perhaps mounting the arms in this location....
Old 08-20-2014, 05:32 PM
With the proper mounting and belts, you should end up with the Mule Drive Pulley alignment like this........Belt Alignment
Old 08-20-2014, 05:46 PM
If the 88" belt worked fine for a long time, I probably wouldn't worry about having the "right" belt.
That said, my 48" mower mounts in the same holes as the OP's and the belt fits fine. I believe you could move the deck back to the aft holes on the carriage with a 48" deck. No way on a 54".
Old 08-20-2014, 06:28 PM
(A) There is something obviously wrong.
(B) The pictures presented, do not reveal the whole condition or situation.
So, we can only speculate as to what is the problem.
