Old 06-25-2014, 08:11 PM
Jethro'sIH182 Jethro'sIH182 is offline
Default Cub 102 engine swap?
I have a cub 102 with the 10 hp kohler (k241). I'm want to swap it out for a 14hp kohler. would this be as simple as a bolt together swap or would this require major fabrication?
Old 06-25-2014, 08:26 PM
It would NOT be a simple swap out.
Old 06-25-2014, 09:22 PM
What he said.
Old 06-25-2014, 09:27 PM
johncub7172's Avatar
Exclamation
OCC member Sam Mac { OCC moderator} made it fit and look easy! Check out his thread on his model 71 for a inside look as to what is typically required in such an upgrade.
Old 06-26-2014, 07:17 AM
As the others have said it's not a bolt in, here is the link to the one I did.
http://www.onlycubcadets.net/forum/s...ad.php?t=20585
Old 06-26-2014, 07:58 AM
cjrolke cjrolke is offline
i thought I read some where that if you took a 14hp block piston and cranks and used the bearing plate, flywheel and tins from a 12or even a 10hp motor you could make it work
maybe I am mistaken
Old 06-26-2014, 08:16 AM
maybe I am mistaken
I think you are right about that. Maybe Jon or Don will chime in.
Old 06-26-2014, 10:01 AM
it would eliminate having to do anything to the frame and look "stock"
Old 06-26-2014, 10:32 AM
Found this in the engine area
http://www.onlycubcadets.net/forum/s...ad.php?t=32011
Old 06-26-2014, 11:36 AM
The OP started two threads on the same topic. I didn't respond, because in the other thread dvogtvpe told him about putting the 12HP parts on the 14 block. Yes, it can be done, but it still isn't a "simple" swap out.
