Go Back   Only Cub Cadets > Resources > Technical Library - Tractors
Closed Thread
Old 03-16-2009, 03:02 PM
Default Kohler - Solid State Charging System
These are the specifications for checking out the Charging System components that were used on the Quietline and 82 Series Cubs...
13.7VDC is typical. 14.5VDC is the Maximum Output Voltage to be seen.
The voltage readings are attained when the motor is at 3600 RPMs or WOT.
Closed Thread
