Go Back   Only Cub Cadets > Cub Cadets > Home Made > Plans, Drawings & Prints
Old 03-28-2014, 01:56 PM
Berwil's Avatar
Berwil Berwil is offline
Default Cat 0 Hitch
I figured I would place the drawings of my cat 0 hitch in this section. The install post is here.
This is the lower lift arm; two are needed. Remember when you drill the hole for the lift link to flip the second arm first so you have a mirrored set otherwise you'll have 2 left arms!
This is the lift link, two are needed. I used left over chrome moly cut offs for the tube, but an upsized mild steel would work just as well.
This is the rock shaft. I added a grease zerk to the top of mine, but I think it is optional as long as you grease it during assembly.
I will update this post as I complete more sketches. If you have any questions, I will try to answer them.
Bill
Old 04-05-2014, 10:57 AM
snoel's Avatar
snoel snoel is offline
Thank You!
Steve
