Old 02-19-2014, 04:33 PM
Default After Market Carb
Just for the heck of it, I ordered one of these from Fleabay. For the price I am willing to see if they will work or not. The only decent one I have left is on the 128 and I just don't think it is working out right. Have never been able to get the governor setting where it needs to be. It does run ok, but not great. I am pretty sure I saw some talk on here earlier about these but didn't see if anyone got one and how it worked for them. I'll try to keep an update on this. I should have it by this Saturday and will be putting it on the 128.
Carb link:
http://www.ebay.com/itm/231108178376...84.m1439.l2649
Old 02-19-2014, 05:05 PM
DoubleO7's Avatar
DoubleO7 DoubleO7 is offline
For sure let us know.
http://onlycubcadets.net/forum/showthread.php?t=29818
Old 02-21-2014, 03:22 PM
dano12's Avatar
dano12 dano12 is offline
I just ordered one of these for my 149, puttin it on this weekend...
Old 02-22-2014, 06:04 PM
I got the carb in today. It's a good looking unit. The first thing I did notice is that the Choke shaft arm, the piece your choke cable will connect to, is 180 degrees backwards. I had a junk carb with a good choke shaft and just simply replaced that so that I can eventually hook up my choke cable correctly. You will also have to remove the 90 degree fuel hose adapter from your old carb and screw it into the new carb body. The throttle shaft arm is designed for the governor linkage that is removable. Again, luckily I had that exact setup on another junk carb. It bolted right up and fired up pretty much immediately. I can already tell with my governor spring in the correct hole on the governor arm that that motor is not surging or hunting like it was with the older carb. I feel that this aftermarket carb is going to work out pretty good. I have some pictures I will add a little bit later tonight. I will probably order another for the motor going into my nephews 73.
Old 02-22-2014, 06:26 PM
Pics of the new carb on right and old carb on left. You can see the difference in the choke arm location.
Fuel line adapter and Governor/Throttle arm mounted
Old 03-21-2014, 12:53 PM
maxd426 maxd426 is offline
Question carb
how has the carb worked out for you i just bought i too put it on it worked fine
but only ran it for 5 min
cub cadet 102 1966
new holland s-14 1970
Old 03-21-2014, 09:40 PM
Pretty much the same here as you. Only ran it long enough to make sure it was going to work. The weather here is still pretty nasty, so I haven't gotten the 128 out to do a shake down with the carb. I still need to reset my RPM's as I was able to set the governor back to the correct sensitivity. The way things are going it will be next month before mother nature starts to give us warmer weather and no snow, LOL.
Old 03-24-2014, 10:19 AM
sgreen3 sgreen3 is offline
Yea Im hoping for a little warmer weather myself so I can get to work on my Cub. Be interested to see how the carb works out. Great price for sure!
Old 03-27-2014, 02:22 PM
samiam44 samiam44 is offline
Can you get parts for it? Will a kohler overhaul kit fit?
Old 03-27-2014, 05:34 PM
dano12's Avatar
Works fine on my 149er No issues at all. Dano
