Old 01-05-2014, 11:21 AM
spudder spudder is offline
Default Rockshaft Brace........
Yesterday, after I fabbed up a rockshaft brace for the 2182 there were requests for pictures.
I made the brace because I was aware of the possibility of shearing the arm off when using a front blade and hitting something solid.
Because I used material on hand, the brace is a lot heavier than necessary. I heated the brace and bent the offset to fit between the two rockshaft arms. Then I drilled holes in the brace including a 3rd hole to bolt the brace to the inner rockshaft arm. To use this third hole, I had to also drill a hole in the inner arm. I had to do this because my brace is too thick to use a hitch pin on the inner arm peg. I actually think by bolting the brace to both arms it's a lot stronger. What's your opinion?
I hope the pictures better explain why the third hole was necessary.
This is not the finished product. I'll refine it and paint it so it looks pretty for visitors!
Old 01-05-2014, 11:26 AM
Looks pretty stout to me.
Old 01-05-2014, 11:32 AM
dag1450 dag1450 is offline
It sure does look heavy duty but r u sure that it will move on the rockshaft with the bolt and the pin? Im thinking u might just want one or the other so things dont bind up. I want to hear how it works cause i need to make a few of these. Dave
Old 01-05-2014, 01:04 PM
Looks good Tim!!!
Dave, they move together, they won't bind.
Old 01-05-2014, 04:26 PM
Looks good to me also, Tim.
Old 01-05-2014, 05:50 PM
Shrewcub's Avatar
Shrewcub Shrewcub is offline
Looks Good!! Thanks for the pictures!
Travis
1993 Cub Cadet 2064
1988 Cub Cadet 2072
1980 IH Cub Cadet 782 w/CH20
1966 IH Cub Cadet 102 w/K301
1961 IH Cub Cadet O
1967 IH Cub Cadet 102 & 122
JD 2155 w/ 175 loader
Old 01-05-2014, 08:02 PM
CTRUEX CTRUEX is offline
Very nice!
Old 01-05-2014, 08:30 PM
The OEM Haban part is stout also. Whenever I take mine off I'm going to make a bunch of them also.
Old 01-05-2014, 08:35 PM
EricR's Avatar
EricR EricR is offline
Yeah, yeah, yeah I heard that last year LOL.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 01-05-2014, 08:45 PM
I'll take one of those, but only if you throw a Haban 54" blade in with it. I already have the cylinder, so it can be a manual blade. They're not worth as much, so I'm sure folks just give them away.
