i just finished the weights for the rear of my 1250.. i found these "chunks" of solid steel at a local bone yard, and after some thinking, welding, grunting,and painting, here they are mounted...i actually have three but only two on he tractor right now..i wanted them easy to take off and on, so i welded handles off of an oshkosh heavy equipment transporter hood on them, and the bracket comes off with two 5/8" stub pins..most of the weight is carried by the heavy cast piece on top of rearend..each weight is about 75-80lbs
Nice job on the weights.
Great paint job on them as well ![]() |
Turned out great!
Top notch job!
looks good
Sharp weight setup.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
Great work. Could you show just the bracket? I may do something simular.
well first of all, thankyou fellas...second; heres some additional pics...hope it helps..the stock i used is mostly 1.5"- 3/8" and some 2"-1/4"... I welded some .5" nuts on the blocks to space them approprietly...and if anyone notices the paint; the bracket is tsc (which SUCKS) and the weights are valspar, which isnt my favorite but much better...hope this helps...just didnt want all the weight carried by the pins, or on the hitch...thanks again
Very clean looking job. Not sure how it attaches up top. The pins fit through the frame?
If I can't fix it , it must not be broken |
yes, the pins actually go through the lift holes....
