Old 11-04-2013, 11:32 PM
dsmithjr's Avatar
dsmithjr dsmithjr is offline
Default 1450 backfire and timing issues PLEASE help!
Ok I am about to go nuts.LONG POST WARNING. I bought a very clean 1450 with a hydraulic lift,headlights and a 50" deck two weeks ago. The PO had owned this tractor the last 15 years. 12 years ago He rebuilt the engine and used it very little and it mostly sat in the garage after he moved to a smaller yard. Before putting it up for sale he got it out and mowed with it several times. While up for sale it began to miss and run rough until it finally would only backfire out of the carb. He had messed with the carb and points until he gave up and reduced the price. I purchased it and all it would do is backfire out of the carb. I rebuilt the carb and installed a fuel filter because it didnt have one. Bought new factory Kohler points and used the static timing method to set them. The engine initially fired up but appeared to be flooding and only ran about 45sec to 1 minute. After that it ran less and less until it began backfiring out of the carb again to the point it blew fire out of the carb. I rolled it out in the dark and observed the points and noticed very intermittent and irregular fire. I went back to check the timing and it was off. I replaced the condenser and went through the process of static timing again but I can not get the same setting more than one time on the points using the static timing method. I am going to have someone more familiar with points check it but I am looking for suggestions from you engine gurus as I am just learning. Thanks Don
Don Smith
Old 11-04-2013, 11:52 PM
I don't understand how you know that you aren't getting the same setting using static time method. Do you roll the motor around and check it again? Try and start it and check it again? .......
Did you check valve adjustment? Sounds like maybe the intake valve is not closing. Adjust the valves and see if that helps.
Old 11-05-2013, 12:03 AM
dsmithjr's Avatar
J-Mech,
Yes if you set it using the guide on OCC roll the engine over and check the "S" and then roll it around again the points will not match up to the "S" again. I may not understand these little engines but shouldn't the points be at the same spot every time to match the "S"? I havent checked the valves but until I get the static timing right checking the valves wont help? I may have to start and reset/check every setting on the engine. Also it will not start at this point only backfire through the carb.
Don Smith
Old 11-05-2013, 12:26 AM
I don't understand what you mean by "same spot". You mean just by looking at them?
Once you set them, yes, just as the "S" appears in the window, the points should just start to open. But it really isn't something that is easy to see. Oh, you probably could, but you really should use a meter or test light. I use a test light. Can't mess it up with a test light. I really don't think using a DVOM is a good way. If you use the test light it will light IMMEDIATELY when the points open. I'm assuming yo are using the guide that Matt G. made, right? If not could you post the link?
Old 11-05-2013, 12:34 AM
dsmithjr's Avatar
Im using Matts guide and my meter with sound. As soon as the points open NO beep should be the same as using a light. This is were I get varied results regardless of what I set the points at:
Now, rotate the engine VERY SLOWLY by hand in the direction of normal rotation (normally clockwise facing the flywheel). When the points just begin to break (open), the meter will fluctuate between zero Ohms to infinite resistance. When this fluctuation occurs stop rotating the engine and look in the sight hole to see where the "S" mark is located relative to the hole. If you performed this step correctly, the "S" mark should be centered in the sight hole at this time (as shown in Figure 6).
Like I said I maybe missing something but its pretty well explained and easy to follow.
Don Smith
Old 11-05-2013, 12:38 AM
Ok, so you are going by the sound. How far off is it? Like is the "S" even visible? Or is it WAY off?
Old 11-05-2013, 12:41 AM
dsmithjr's Avatar
I guess it would make more sense to say set on .20 the "S" doesnt line up so I move to .18 and reset everything. Logically the "S" should move closer to the center mark and eventually I should be able to reach a setting that results in the correct timing by follwing the adjustment procedure. However so far I have not been able to get any consistenty.
Don Smith
Old 11-05-2013, 12:45 AM
dsmithjr's Avatar
At .20 my "S" is above the line. At .18 I can not get a consistent reading on the "S". At .15 it is way way below the line. Sometimes I can go through a complete revolution and even thought the points appear closed NO beep. These are brand new points but its like they wont come together enough to trip the meter.
Don Smith
Old 11-05-2013, 12:50 AM
OK. Stop. I got it now. Here's the problem. The points aren't getting set on the top of the base circle of the cam lobe. Put away the feeler gauges. Put the "S" in the window and set it with the meter only. When it quits beeping, lock the points. Roll the motor and check it WITH THE METER ONLY and see if it's the same. Forget the feeler gauge it's throwing off your setting and they are not necessary.
Oh, and you should file the new points with either some emry cloth or a point file before setting. Clean them with a dollar bill folded three times while they are closed.
Old 11-05-2013, 12:58 AM
dsmithjr's Avatar
That sounds very logical actually. I did clean them like you said after the initial start up before this go around of timing. Ok just to double check. My meter beeps when the points are closed. So right now they are at an initial setting of .20 so move them closer until I get NO beep and the "S" on the center line? Correct?
Don Smith
