Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Engines > Briggs & Stratton Engines
Old 10-16-2013, 04:24 PM
Default Vanguard ring gear replacement.
Found a flywheel from a guy on MFT that had the correct ring gear for the Vanguard that came in that 1641 I bought from Earl Sarvey a while ago that was missing 2 teeth. Of course Briggs no longer sells just the gear they want you to buy a complete flywheel for about $250.00 and no way am I going to put that kind of $$$ into this engine. Figured I’ll gamble a few bucks for a used gear and some gaskets and push rods. Anyway I drilled the rivets out that hold the gear to the flywheel. Then I drilled the holes in the ring gear ¼” , tapped the holes in the flywheel ¼” -20 and bolted the gear on. Fit’s nice so now I’ll buy the other parts I need to fix this old abused girl up. Next problem will be what to put it in once I get it running, can’t have a running engine just sitting around now can we.
Old 10-16-2013, 06:03 PM
Cool! Is that an aluminum ring gear?
Old 10-16-2013, 06:17 PM
Yep it's aluminum.
