I had mentioned in a post about overhauling a 44”GT deck that the bearings in the idlers can be replaced so here is a quick how too. First you drill out the spot welds or grind off the rivets depending on how it is put together. Split it in half with a chisel. Remove the old bearing and then press out the spacer. Install the spacer in the new bearing and then bolt the whole thing back together. I use red Loc-Tite on the nuts. These pulleys used two different bearings the most common seems to be the 6203 McMaster Carr part number 5972K44 it’s a metric bearing for a 17mm shaft the other is smaller it’s part number 2780T61 and it is for a 5/8” shaft.
I like your style. Fix rather than replace.
Mike
I am so tired of the throw away mentality in this country these days. The Metric bearing is a whole $6.02 and a new pulley is about $25.00 and it's and easy fix. Even easier now that it's been drilled and bolted. I have 2 pulleys on a mule that I would do the same thing with but they are welded together in the bottom of the groove.
Great Job!
Good idea Sam!
You da man, Sam!
Great job Sam, thanks for the information.
I really think information like this should be saved in the tech section.
Sam,
That is a great idea repairing the idler bearing. I had never thought about a repair and have replaced half dozen or so over the years. Regards, Chris
Casbohm Maple and Honey www.mapleandhoney.com Cubs: 147R and the "train", 127 elec lift, 127, 125, 106, 102, 100, 86, 73, Brinly plow, Snow thrower, 2 Rototillers, several mower decks and several snow plows, #1 cart, Grandkids barrel cart. |
Thanks for the comments guys.
Thanks for the tutorial Sam...
