Been doing some work on my 784 and this has always had my head scratching..
![]() The engine is mounted to a base plate with 4 of these spacers (950-3009) They seem to "dig" into the base plate and/or the engine foot. The dimensions of these spaces are: ID: .423" (for a 3/8" bolt) OD: .675" Height: .469" ![]() I was toying with the idea of just putting (2) - 1/2" piece of flat stock (either steel or aluminum) and drill the appropriate holes on each end. Height: .50" Width: 1.50" Length: 9.00" I think these would give greater support. ![]() The question I have is, there will be a difference of .31" in the engine mount height. Is this going to be a major concern...??? Or should I go 3/8"...??
I don't really know, seems the only issue would be at the driveshaft. The difference should be .031" not .31" as stated which is closer than 3/8" would be. I can't believe the driveshaft alignment is that critical.
I think you would be fine.
No more difference than that is, it will be fine.
Well, Cub Cadet wants $9.00 each for those spacers = $36.00
I bought two pieces of flat stock for $2.00. Four holes and a little paint, and some left over for a brewski or two. ![]()
I honestly had not thought of doing this. Next time the motor is out of the 1811, I believe I will! Never liked those small spacers either..... Just left a lot of stress on the motor flanges! Great idea!!
That's an excellent idea, Roland!
Well, here is the finished product. I bought 3/8" (.375") flat stock. Measured and drilled holes for the 3/8-16 bolts.
I decided to use 3/8" x 1-1/2" fender washers to add to the height. The washers are .055" thick. I'll be .039" too low with one washer or .016" too high with two washers. I am thinking this will offer far superior support.
I'd go with the 2 washers but I doubt that you would ever have a problem with 1 washer. Just my 2 cents but I would have used the 1/2" you were thinking about earlier.
Not to bring up a super old thread, but how has this worked out Roland?
I have an engine to mount and only 2 spacers to mount it with. Considering going this route instead of picking up more spacers (or making some).
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
