Old 06-21-2013, 09:24 AM
nikster's Avatar
nikster nikster is offline
Default Point saver; Question?
Getting ready to attach point saver thingie on my # 127- 12hp., Kohler.
Before doing this i'm somewhat puzzled at the BEST location as to mounting it? I'm wondering if any-one else has one where did you mount your's?
This is a NO-BRAINER to hooking up & mounting but i dont want to have to change locations.
Thanks in advance.
Nik,
Old 06-21-2013, 09:27 AM
If it were me, I would mount away from....heat and vibration.
Old 06-21-2013, 09:30 AM
TommyK's Avatar
TommyK TommyK is offline
Nik, i installed a pointsaver, but it's on my WF 108. I installed mine on the RH panel extension.
Old 06-21-2013, 02:59 PM
austin8214's Avatar
I installed both of mine on the left side just under the battery box.
Old 09-05-2013, 08:58 PM
counciltucky's Avatar
counciltucky counciltucky is offline
I have a 108 and i installed it on the left fuel tank bracket
63 original
64 cub 70
65 cub100
67 cub 104
108 puller
127 hydro
129 hydro
149 hydro
Constitutional conservative
Old 09-05-2013, 09:23 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
how often did guys change your points that you need a point saver? My K321 I put a set of points in when I rebuilt it back in 84 or 85 . I use a 0 ohm Chevy coil with a strategically placed resistor. they are still in it today. My
K241 I have no idea when the points were changed. On our pullers the only reason we went away from points was how much timing changed through an RPM range.
Old 09-06-2013, 09:54 AM
TommyK's Avatar
When I bought my 108 it ran but the points were pitted really bad. I installed a pointsaver when i replaced the points. Also replaced the used coil with a Bosch Coil. Pointsaver replaces the condensor. What i really like about the pointsaver is it's incredibly easy to set the timing. When the points open, the light comes on.
