Old 12-09-2009, 07:02 PM
dieseldog558's Avatar
dieseldog558 dieseldog558 is offline
Default ih cub 1200 paint
what kind and brand of paint does everyone use......even if it is spray can? i am getting ready to paint my 1200.......prob by a spray can......does krylon make a color that is close to original paint?
Old 12-09-2009, 07:21 PM
wshytle wshytle is offline
Rustoleum #7770 almond is very close. I compared it side by side to IH white after spraying and letting them both dry. As far as the yellow, I took a small sample to my local hardware/paint store and the guy did a computer match. I haven't been able to find a yellow in a rattle can to match IH yellow. If you don't have paint spraying ability you might have to settle for a yellow that's a little different or you might get lucky and find a closer match than I have.
I would also use a gray primer instead of red oxide. The lighter color doesn't effect the color of the finish coat as much (so I've been told).
Good luck...Wayne
Old 12-09-2009, 07:24 PM
bignastyGS's Avatar
bignastyGS bignastyGS is offline
Go to Tractor supply. I bought both Yellow and white Valspar rattle cans and it's a factory color match 4.99 a can. I did my back rims with 1 can. I then stocked up on 5-8 cans.You will be impressed at the color match!!
Edit...Valspar numbers are 5339-26 white 5339-25 Yellow.
If I were restoring a tractor, I would also go to Napa and have it mixed ,but I am not no painter and I am happy enough with. Merk has some dandy looking tractors there,but I would be afraid of scratching them if I owned them.
Pat Harmon
Loganton,Pa
128 Cub Cadet
1200 Cub cadet (Red)
LT 1042 Cub Cadet
1200 Cub Cadet
165 Hydro John Deere
1941 John Deere H
1950 David Bradley 5756
1952 David Bradley 57561 Super Power
Old 12-09-2009, 07:44 PM
Merk Merk is offline
I use Napa brand Cross Fire acrlic enamel paint.
TSC sells a paint that is close to the yellow and white that Cub Cadet uses.
It's close...not close enough for me.
Old 12-09-2009, 08:11 PM
mstetar's Avatar
mstetar mstetar is offline
haha as im reading i keep looking at the box of NAPA crossfire paint that sitting here waiting for me to get off my lazy butt and get my 100 sandblasted
check out my cub site
Old 12-10-2009, 12:15 AM
Leon renaud Leon renaud is offline
Hey Merk do you have the paint codes for the Cub colors?I don't like the idea of spray bombs to paint my stuff on a complete machine.
Old 12-10-2009, 02:00 AM
dieseldog558,
If you are going to use spray bombs, then the Valspar from TSC is the way to go, the color match really is pretty close and the price is pretty good too.
I use it a lot for individual parts, Cub Cadet Yellow 5339-25 and Cub Cadet Beige 5339-26 just like bignastyGS said.
Old 12-10-2009, 03:16 AM
PPG Shop Line acrylic enamel....
Old 12-10-2009, 06:08 PM
by Leon renaud
Martin Seynour/NAPA:
IH901 = 99L-3965; Crossfire 53A-3965
IH902 = 99L-10649/99L-3416; Crossfire 53A-10649, 53A-3416
IH935 = 99L-11934; Crossfire 53A-11934
IH483 = 99L-3857; Crossfire 53A-3857
There was 3 different whites used during the IH Cub Cadet years. They are
White
901
Period used: Beginning to 11/1967
Serial numbers: Beginning to 218009
Cubs used on: ORIG, 70,100,71,102,122,123
902
Period used: 11/1967 TO 2/1971
Serial numbers: 218010 TO 375938
Cubs used on: 72,104,105,124,125,73,106,107,126,127,147
935
Period used: 2/1971 TO PRESENT
Serial numbers: 375939 TO PRESENT
Cubs used on: 73,106,107,126,127,147,86,108,109,128,129
149,169,800,1000,1200,1250,1450,1650
IH483 is the yellow paint.
Old 12-10-2009, 07:24 PM
MBounds's Avatar
MBounds MBounds is offline
Leon: There's also:
IH 901 Harvester White: PPG 8665; Navistar 0901
IH 902 White Cap White: PPG 90592; Navistar 0902
IH 935 International White: PPG 91607; Navistar 0935
IH 483 & 483B IH Federal Yellow: PPG 81518; Navistar 0483
IH 2150 IH Red (the 82 series): PPG 71310; Navistar 02150
IH 1150 IH Implement Blue: PPG 10067; Dupont 25160
Myron B
CCSupplyRoom
