Old 01-26-2013, 08:04 PM
CadetTY's Avatar
CadetTY CadetTY is offline
Default Fixing up my ole 1100
Started as this. Steering wheel was taken off miss matched hood, gas tank is missing. Engine runs but needs a new carb. Drives great to!
Started taking it apart
Rear end out
882 diesel, x3 ih 582, 73 124, x2 82 seriers pullers, 1686 16hp puller
Old 01-26-2013, 08:12 PM
CadetTY's Avatar
Primed hood and grill pieces. I 80 gritted the inside and out of all the panels to bare metal. Wire wheeled the rust then straightened any dents with a dolly and hammer and alil bondo after sanding bondo i 180 gritted everything for primer
3 coats of the case ih iron guard primer baked for an hour and sit for the weekend.
This coming week i will sand the dash and clutch covers for primer!
Old 01-26-2013, 08:30 PM
CadetTY's Avatar
The power plaint put aside till the tractors ready for it
Old 01-26-2013, 10:25 PM
You're making some nice progress! Please keep us updated.
Old 01-27-2013, 12:54 PM
CadetTY's Avatar
There will be more to come for sure!
Old 01-27-2013, 06:04 PM
Sounds good! Looking forward to them.
Old 01-30-2013, 08:08 PM
CadetTY's Avatar
Update everything is ready for prime except the fiber glass dash piece. I will work on it tomorrow and sand and repair a small crack and hope to have it in the paint booth friday night! Then all my white pieces will be primed and ready for some white paint the following friday!
Old 01-30-2013, 10:12 PM
Appreciate the update!
Old 02-05-2013, 09:59 PM
dag1450 dag1450 is offline
Looking good. I have a can of that case ih primer and there are no specs or mixing info at all, i think it says mix with case ih reducer or something like that. What did u mix yours with and to what ratio? Thanks .Dave
Old 02-07-2013, 07:11 PM
CadetTY's Avatar
I mixed 4 of primer and 1 of thinner (reducer) and 1 of valspar hardner to speed up the curing time 3 coats are plenty for me i will have to sand my fiber glass dash piece and prime again because the 1st 3 coats didnt fill the 180 scratches very well so this time i will 400 grit then prime
