Old 01-06-2013, 01:33 PM
Default Fast way to get brake pads off of the backing plates.
I’m doing a brake re-line job on a set of brakes that will be going on my 71. Rather than soaking the pads as Matt did in this write up (http://www.onlycubcadets.net/forum/s...ead.php?t=1308) or grinding them as others have done I heated the backing plates up with my cutting torch, the old pad material fell off in a couple minutes. Just make sure you have plenty of ventilation this stuff is toxic.
Old 01-06-2013, 08:40 PM
Now that is a HOT idea!!
Old 01-06-2013, 08:50 PM
Smokin HOT LOL
Old 01-07-2013, 08:11 PM
EarlJ's Avatar
EarlJ EarlJ is offline
Sounds like a great idea, I'd be curious to know if the heat would weaken the metal to where it could crack upon applying pressure. I know it's not a ton of pressure but if it were to crack it would cause problems stopping, particularly going down hill such as in my yard..Thoughts??
126 in surgery with weights, spring assist, 3 point and sleeve hitch
100 with woods finish mower and rear lift,
Nice 125 with super nice sweepster, 1782 Super Diesel,
1650,782D in surgery, 102 parts tractor..
3 Brinley plows, Brinley cultivators , rear scrape blade, front plows and custom built bedder attachment.
Old 01-07-2013, 08:32 PM
Runaway tractor...JUMP!!!
Old 01-07-2013, 08:54 PM
Earl
Doubt that it will weaken the backing plate. I’ve done the same thing to remove pad material from race car brakes in order the use the backing plates as spacers between the calipers and pads that were ½ worn. Never had a problem. You don’t need to get them all that hot in order for the glue to break down.
Lew you’re a riot. I can see you with a parachute or an anchor.
Old 01-07-2013, 11:24 PM
That will have no ill effect whatsoever unless you throw it in a bucket of water when it's red hot.
Old 01-08-2013, 02:58 AM
jacobd jacobd is offline
...or an anchor.
You know I was just thinking about how to fab up some missing break linkages but I like this better. Just tie it to the hitch and toss it off your lap when you want to stop
Old 01-08-2013, 02:07 PM
Took a pic of the backing plate with the removed brake material for you guys
Old 01-11-2013, 09:02 AM
I got my brake pad material from McMaster yesterday. I bought the 1.5” wide material because I’m lazy and didn’t want to have to make an extra cut. Part number is 6175K813 and it is 4’ long so I have enough left over to do another set of pads. Cost was $24.79 delivered. Cut the pads on my chop saw. This stuff cuts like butter with the saw. I did make the pads a bit larger than what came off the backing plates.
