I have a 107 hydro...that was eating PTO belt (mule drive)..I tried aftermarket belts..and pulleys on the mule drive..same thing..could not keep a belt on and eventually tears the belt...I put IH/CC pulleys on and IH/CC Belt and now no problems...Does this sound familiar with anyone??? Would it really make the differance???
Yep, aftermarket belts just can't handle the twist and wear like Cub belts are designed to do.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
I used to run the gates green belts 20 years ago on my 147 and the worked great. the ones they make today wont last a week.
Thanks for the info....
F.W.I.W.
Belts are made for specific applications. When a belt makes 1/4 twists and goes around idlers, it needs to be designed with materials that will withstand that. There are aftermarket belts that withstand those conditions and I have/am using them, but they are not inexpensive. They cost just as much as a factory belt designed for that application, sometimes more. But there are times a non stock application length/width is required, thus the aftermarket suppliers provide that. If a belt just goes between 2 pulleys, with no special needs, most any belt will work. Goodyear "insta-power" series is one that will withstand the 1/4 twists/idlers/heat in a mower/mule drive application. I'm sure there are other manufactures. I have seen this in the farming industry as well as the auto industry, where I spent 40+ years. By all means, if a factory designed belt is available go with it, as in the long run you are always dollars/time ahead of the game. |
Most lawn and garden belts are odd sized, say 72 3/8 etc., The local parts stores carry fully sizes 72,73,74 etc.. so you get one a little tight or a little loose, most mowers dont have the adjustment capacity for this,,, and part store belts are just "belts". buy belts from a lawn and garden shop and spend a little extra, and you'll be $ ahead
Speaking of belts, does anybody know the correct part number for the PTO to deck drive belt on a 782?
782 882 |
Which deck do you have on it?
It's a 3 blade 50 inch, I think a 50c
782 882 |
