The guy I bought this from said one was a narrow frame setup and the other was a wide frame. I have a 127 and can't seem to make either fit right. The narrow frame one looks like it was modified. I've got more photos if it would help.
Thanks Bill |
yes they are the right ones they seem to be maybe you didnt hook them up right
The 127 will use the narrow frame, the one on the bottom. It looks like it's missing the 1/2" nubs on the inside. You could probably use a piece of 1/2" round stock that is around 12" long stuck through the holes in the tabs. That may do the trick.
CCC 784 w/ Triple Hydraulics IH 982 Cub Cadet Commercial H1748 Walk-Behind 50C Deck 42" Hydraulic Angle Front Blade 41" IH Rear Blade QA42A Snowthrower |
The narrow frame one has the arms further apart and the wide frame one has the arms closer together. You may need to loosen the footrests to get the NF one to fit on them and sometimes its a very tight fit!
You're very lucky to have the versatility to adapt a blade to either a NF or a WF cub!! Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
Hi All,
It looks as if someone lenghted the narrow frame brackets, and made it longer as seen in the photo. Mike
1991 1882 |
The problem with the one on the bottom of the photo is that once I get it in there, I can't move the life lever because the nubs on it hit the plow frame right where those pieces are welded in. That with the plow frame hooking to the very outside of the attachment bar near the trans. Should they be going inside like where the mower usually attaches?
The NF undercarriage should hook on to the front supports of the footrest, outside of the frame. In a thread by ACecil, quite some time ago, I had sent some pictures of attaching the NF blade on my 73. I looked hard for the thread that contained it, but came up short. Perhaps Allen still has that pic or can find that thread for you. I'd take another picture, but my 73 is 40 miles away from me right now.
![]() Quote:
Goes OUTSIDE the frame you say? (forehead slap) I tried looking in the tech section but it I didn't find a CC blade just the brinly stuff. The front hooks into the quick connect jaws? Thanks a bunch. B |
![]() Quote:
http://www.onlycubcadets.net/forum/s...150#post110150 |
Thanks! I figured they were around somewhere but I couldn't find them. The plow sub frame need some "persuasive adjustment" , thats why it wasn't going on there.
