Old 07-11-2012, 01:58 AM
72-149's Avatar
72-149 72-149 is offline
Default cub low boy hubs on a 982
i got sick of the center bolt coming lose on the left side of my 982 ,so i happen to notice that the cub low boy has a 1" front spindle similar to the 982 so i bought a set of front hubs & took a harden bolt and cut the head off and screwed it in the hole where the center bolt go's in the spindel with some loctite & put it together and then so the nut wont back off i drilled a hole in it and put some mechic's wire in it! & for front rims i used those other color tractors back wheels on the front of the 982 they are 7" wide x 8" rim with the right bolt pattern. international should of done this from the factory on the supers instead of doing the super like a lawn tractor !!!
Old 07-11-2012, 07:30 AM
Default cub cadet 982
thats cool good work i bet it will look great
Old 07-11-2012, 11:08 AM
Great job!
