Old 11-21-2011, 07:09 PM
CHWNY's Avatar
CHWNY CHWNY is offline
Default Port bypass
I have a PORTED hydro pump and want to temporarily bypass the ports, So I can use the tractor while repairing and upgrading the lift systems.
Can I just loop the two ports w/tubing?
if so
What diameter would be best 3/8"or 1/2"?
Would Compression or Flair fittings be best?
Thanks
Clay
Old 11-21-2011, 07:15 PM
LarryW's Avatar
LarryW LarryW is offline
I have pretty much the opposite. A ported pump that has never been used from a 129. Going from opposite of what I have to do, you can remove the sping and cone on the side of the pump and then just cap off the hoses.
Cub Cadet 147 2050041u340160
Cub cadet 129 main mower
Cub Cadet 1811
Old 11-21-2011, 07:18 PM
LarryW's Avatar
Think backwards of this, lol. Page 9 is what I think you would want. http://ccmanuals.info/pdf/169%20Hydr...On%20Setup.pdf
Cub Cadet 1811
Old 11-21-2011, 07:31 PM
CHWNY's Avatar
AHHH, GOT IT....I stood on my head to read it
Clay
Old 11-21-2011, 07:36 PM
SwampRatt-1977's Avatar
so you just remove spring and cone from charge pump relief valve (on the side right?) and plug lines??
Old 11-21-2011, 07:40 PM
CHWNY's Avatar
Yea If I'm reading correctly. It looks like some came like that and you could add hydro lifts.
Clay
Old 11-21-2011, 07:41 PM
LarryW's Avatar
lol
Its saying to swap the springs around. Not sure if you have to worry about that or not. But my charge pump spring and cone are missing completely so I think that is so it can just bypass inside. I was looking around for a hydraulic circuit of the pump innards with no luck the other day. I thought I saw one once. I have to search some more so I can understand it all better.
Cub Cadet 1811
Old 11-21-2011, 07:54 PM
it cant wreck anything by looping the the ports together though right. because i dont want to take my spring and cone out and loose them lol.
Old 11-21-2011, 08:15 PM
CHWNY's Avatar
That's kinda what I would like to know also. I seem to lose important things like that too.
Clay
Old 11-21-2011, 08:17 PM
CHWNY's Avatar
Larry, I thought you would need the charge pump spring? how does yours work w/o it?
Clay
