I am looking for a drawing or sketch of the 1" diameter pin that goes in the draw bar hole to lift a tiller on a 1450 cub so I canb make one. Length, stop collar location, cotter pin hole location and height adjustment hole / slot location and dimensions.
![]() Thank, Doug |
Is this what your looking for?
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
Is this photo in the tec. section? If not it should be. It was posted several times lately.
Clay |
I posted that picture for some else. That wont work on a tiller. Well it would but too long. The lift point is shorter. I have 1 on the shelve I can measure for you.
I think it is too long and I dont recognize the second hole at the lift end.
Thanks though. |
If you could I would appreciate it!
question,,,
if the hole is further away in the pin, would the tiller lift higher? ( would be heavier too) my trailer is a tilt bed , and im afraid the tiller will bottom out before it heads up the trailer. the plow I can just pull the pin. not worried about that. if the pin was longer, with 2 holes. then when loading it on the trailer move the chain to the far end hole to lift it higher.
Doug Original , 100 , 125 , 582 ![]() ![]() ![]() ![]() West Central Ohio Farmall & Cub Cadet Club https://www.facebook.com/#!/groups/226681087497199/ |
that picture is a good start. from what i have seen is that the original one has a slot in it. im not for sure why though. i would like to get the dimensions for an original one. I also need a tiller depth adjustment knob and the threaded rod that holds the chain. does anyone have dimensions for these?
1979 1650, #1 tiller with one extension, 90 degree box mounted, 3 point. 1961 4 digit bringing back to life. I have the mower and 3 pint for it. The 1650 is the fastest mower in the neighborhood. |
