I am looking for ideas on how to clean the fuel tank for the little 73. It looks like it has a lot of varnish inside and smells of really old fuel. I have never had to clean the inside of a tank before and thought I would get some ideas on how to do this from you guys.
Thanks
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
When i cleaned the new to me tank for my 123 i did a mixture of CLR and BB's. Shook it up and let the bb's knock the rust loose and the CLR ate the rust and gave a clean finish. Then when i had the desired cleanliness i filled the tank with diesel fuel to seal the tank. Dumped the diesel, forget how long i had it in there, and let it evaporate to get all the diesel fumes and remaining diesel out for a few hours. Replaced the gas cap, and cleaned the fuel bowl and all was good as new!
1967 IH Cub Cadet 123 1978 IH Cub Cadet 1650 19?? IH Cub Cadet 682 |
![]() Quote:
you can do it the automotive way immerse in a hot tank with degreaser for 1/2 a day, also could try a immersion type carb cleaner
![]() Quote:
50/50 mix of muriatic acid and water. Fill it to the brim and leave it for about half an hour, then empty it, rinse it with water, and then put some 2-cycle oil or diesel fuel in there so it doesn't rust.
Don't forget safety goggles (not glasses), rubber gloves, etc. and remember to add acid to water and not the other way around. |
A handfull of 1/4 nuts, rocks or bolts with acetone if removing varnish and shake,shake shake!
Recently did this. I'd decided not to use acid and opted for a product called evaporust (sold at autozone). Filled the tank and rotated daily for about a week to reach all surfaces. Had some cosmetic scale on the bottom I removed by taking a small cup brush mounted in a paddle bit extension on a drill.
Unfortunately this tank had baffles in it leaving areas I couldn't see or get to. Did a flush with thinner then lacquer thinner. Finding a little rust in my sediment bowl, hope it passes after a tank or two.
Wore out 129. Projects: 1969? 147, 1971 chevelle SS conv 402/4sp bench, 1965 chevelle wagon, 1973 trans am drag car, 1973 triumph 650 chopper, and oh yeah, working on the house too! |
I did electrolysis inside of the tank on my O. I've got some pics somewhere, but it did a great job. Used the tank itself as a ground and stuck a rod on the inside without touching anything else. Didn't take too long at all.
Gary '49 Farmall Cub, '62 "Original, '70 73 w/402-D Haban sickle, '71 127 w/38" cast end deck, '73 149, '76 Sof76, '07 LT1045 w/bagger, '09 GT2544 w/bunch of mods. 5 Exmarks, Kubota B2920, blah, blah, blah... |
