Old 08-11-2009, 09:07 PM
Default Why NOT to put Calcium Chloride in your tires
PUBLIC SERVICE ANNOUNCEMENT:
This is why you should never, ever, ever, EVER put Calcium Chloride in a tubeless tire.
I personally wouldn't be putting it in a tubed tire, either...
Old 08-11-2009, 09:27 PM
Mike in NC's Avatar
Mike in NC Mike in NC is offline
Never saw one THAT bad before. But I never saw a tubeless tire with it in. There was a bio-degradable substatute that a tire dealer told me about around 15 years ago. Said you could put it in a tubeless tire and it would not hurt the rim or tire. He said it was around the same weight as CC but a lot safer.
Mike Murphy Mike & Jen's Old Engines Original OCC Member #23
Cub Cadets: 102, 128(X2), Model 1 tiller, Model 1A Sweeper, QA-42A Snow blower, 38" CI end mower deck, QA 42" mower deck, Brinly cultivator, Brinly 10" plow, sleeve hitch adaptor
Old 08-11-2009, 09:41 PM
murphycc
Guest
Posts: n/a
Dawn dish soap! Won't freeze. Won't rust.
I know ALL of you will argue with me, I'm a nutter. Do as you will.
8oz to one wheel/tire with water.
Scott
Old 08-11-2009, 09:49 PM
deputyrpa's Avatar
deputyrpa deputyrpa is offline
For some reason I can't see the pic, but I've seen a lot of calcium chloride results. I use RimGard in all my tractors. It's beet juice....basically. It's heavy too - adds 502# to one 14.9 x 24 R1. I can also tell you it doesn't taste too good, especially after being in a tractor tire for a few years.....
Old 08-11-2009, 10:01 PM
papaglide's Avatar
I can't see the pic either. But I have a silly question: how might I add soap and water or any other liquid to my tires. Take out the valve stem and pump something in?
Old 08-11-2009, 10:07 PM
murphycc
Guest
Posts: n/a
Go to TS and in the tire section you'll find a hose to stem adapter to about $12 IIRR, works great. And the Dawn, just lay wheel/tire on it's back and open the spout on the Dawn and let it run in the stem, once streaming it'll go right in.
Scott
PS. as Matt warns about breakage, soap is harmless.
Further- soap changes the ph level of water, I'm not a chemist so don't ask me how but it inhibits rust. Also I tested this last winter and we have several days in a row of 9 degree cold and tires did not freeze.
Old 08-11-2009, 10:54 PM
deputyrpa's Avatar
That's a lot of soap! A picture flashed thru my brain just now - it was a flat in a rain storm! THAT's a lot of suds! :biggrin2.gif:
Old 08-12-2009, 06:48 AM
papaglide.
Here is the setup i use. Works pretty well.
I fill the bucket with windshield washer fluid (or what ever you are going to use) Then my pickup hose to the pump. From the pump to the tire, going through the adapter.
Bought this drill powered fluid pump at the hardware store. Wasnt sure how long it would last, but it has filled 8 23x10.5-12 tires so far. It was less than $20.00
This is the adapter i use. It hooks to the end of the garden hose from the pump and hooks to the valve stem of the tire. You have to stop the pump every so often and let the pressure out . There is a little button valve on the side of the adapter.
Old 08-12-2009, 11:52 AM
Great write up and pics Diz! Thanks for sharing.
Old 08-12-2009, 04:11 PM
ajgross ajgross is offline
Inactive Member
I use "Rimguard" also. The stuff weighs 11lbs per gallon. It's toally biodegradable and even aproved as animal feed. I haven't really checked around to compare prices, but I paid $3.85 per gallon the last time I had tires filled. Here's the link: http://www.rimguard.biz/
AJ
