![]() And so the saga begins...
For those not in the know, the PTO on my 2284 failed recently and I ordered a new one. Less than 30 minutes after installing the new PTO, the engine in my 2284 blew up (bad timing?). So since I had a line on a GT2544 for $200 with a good low hour engine (meter showed less than 330 hours), I nabbed that to do a motor swap. Pics and info will follow. Below are a few pics of the donor tractor. Original owner got rid of it because the deck is basically trash (rough around the edges, bent shafts, etc). The tractor itself isn't in bad shape. It actually has the headlights in which seems to be rare for this generation. Little to no rust, engine pops off first crank but the trans or trans linkage is bad. Reverse is fine but forward is a crawl. Either way, this machine isn't going to get another life so apart it comes. Below are a few pics of the donor machine and the 2284 that will receive the new heart. Stay tuned for more pics and progress info! And as always, click on the small pic for a larger image ![]() ![]() ![]() ![]() ![]()
-Ryan
I wonder if the new engine has a 1" shaft or if it's 1-1/8" it would suck if you can't use the new PTO. It may also have large dip stick tube that interferes with the muffler, you can fix that problem with a BFH, BTDT.
Dipstick appears to be in the same spot, I'll let you know on the pto. Either way it has a pto so worst case I can use that one....I hope!
-Ryan
![]() Quote:
Ryan, you're getting ahead of yourself bud. ![]() https://www.kohler-engine-parts.opee...nkshaft-p-5614
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
I didn't know the motor had for sure failed.......
We need an update.
Today is work day so expect an update this evening! I've got fellow member from here Cadetbob coming over in a couple hours here and we're going to tare into things. First order of business is to confirm the status of the 2284 engine (dead or seized PTO). Then after that, one way or another, I'm finally going to finish getting my lawn cut even if I have to go out there with a pair of hand shears and do it one blade of grass at a time!
-Ryan
Yep, I'm out of
![]() ![]() Guess he's still cutting with the shears.
I think this thread needs a poll who thinks Ryan has a PTO or an engine problem.
I know the answer
Turns out being an adult is mostly just googling how to do stuff... |
